Home > Maintenance & Mods (L322) > So here is what is lurking behind my sills and arch liner. |
Highroller Member Since: 18 Jul 2016 Location: Hampshire Posts: 565 |
wow - Best one I've seen |
31st May 2022 4:27pm |
philip1972 Member Since: 16 Jun 2017 Location: Marval 87440 Posts: 523 |
I am pleased to say the least. Still gave it a coat of stuff for precaution, thought I may as well while I was in there.
31st May 2022 4:30pm |
dingg1 Member Since: 29 Jun 2013 Location: PORTUGAL Posts: 1340 |
Has it had a sheltered life?
31st May 2022 4:46pm |
JCW Member Since: 13 Apr 2013 Location: Cotswolds Posts: 861 |
Rear arch liners are a pig to refit - trick I found helped no end was to leave them in hot sun for a good while which makes them more flexible to wrestle back in. |
31st May 2022 4:54pm |
Good tip on leaving in the sun.
31st May 2022 5:02pm |
No salted roads in Jersey
31st May 2022 5:26pm |
redsportt Member Since: 30 Dec 2015 Location: n ireland Posts: 14 |
a lot of cold starts and engine not heating up properly is the downside of small island cars |
31st May 2022 7:14pm |
Tut is very true, but unlike my previous big Diesel engines, the petrol seems to get up to temp in about 2 miles! |
31st May 2022 8:00pm |
oggy Member Since: 09 Sep 2020 Location: padstow cornwall Posts: 395 |
you want to make sure that the drain slots in the sill to body panel are nice and clear i use a old hacksaw blade and slide up and blow them out with a air line . and remove all gromits along sill and spray some lanoguard in to the cavity this is nice and thin stuff and will not block the drain outlets if water is getting in it has to come out its when outlets are blocked and then you get the rot problems use a thicker protector on the outside i have used epoxy resin all in around my wheel arches and outer sills this will stop any more surface rust returning time consuming but job well done at the end new vehicle purchase
1st Jun 2022 11:18am |
Superspoons Member Since: 24 Jun 2010 Location: East Hertfordshire, UK Posts: 391 |
They really are in excellent condition .. mine needed some attention -
1st Jun 2022 11:38am |
