Home > Maintenance & Mods (L405) > Damn, guess I need to lose some weight....
marcochezzi
South Africa 2011 Range Rover Vogue SE 5.0 SC V8 Fuji White
The photo tells it all, I assume this is a common problem with the lower tailgate cable things eventually fraying to a point of breakage, as I discovered today while positioning my rear end gently on the open tailgate..
Made a horrible sound, the tailgate that is...
Wonder how much this little cable and spring affair is going to set me back..
Post #632882 25th May 2022 4:34pm
the L322 tailgate straps break because of rust on the cables but i've not come across the L405 cords breaking.. ... - .- -.
Post #632883 25th May 2022 4:37pm
marcochezzi
Yep, just my luck, and we hardly suffer from rust in my neck of the woods.. I've removed all the bits and pieces that makes up this little affair, sadly its not just a matter of replacing the cable as the cable glands on either end are too big to fit through the spring and shiny pieces, so clearly supplied as a fully assembled part, including that expensive looking chromed bit..
Probably going to have to wait 2 months for this part to get to our shores..
Go figure...
Post #632884 25th May 2022 5:00pm
''Probably going to have top wait 2 months for this part to get to our shores.. ''
plenty of time to loose some weight.. Mr. Green
Wink ... - .- -.
Post #632886 25th May 2022 5:06pm
marcochezzi
Laughing Laughing Laughing True that Stan, my wife would agree…!!
Post #632887 25th May 2022 5:12pm
Happydaze
United Kingdom 2007 Range Rover Vogue TDV8 Java Black
I'd be thinking that a control cable supplier / maker could replace the broken cable fairly inexpensively. Got to be worth asking the question?
Chris
Post #632898 25th May 2022 7:35pm
marcochezzi
True, thank you very much for the suggestion Happydaze Thumbs Up Thumbs Up, did not even cross my mind... I'm going to go to JLR and see what these things cost just for kicks, but thankfully have found a control cable manufacturer 15 minutes away that 'hopefully' can do this for me, certainly looking at their website I would guess this is pretty doable..
I have stripped out the good unit on the left side of the tailgate so we can match for length, which is important as there is a stopper in there preventing the tailgate from dropping too low..
Post #632924 26th May 2022 6:23am
I've got one of those boring bar holders.
Post #632933 26th May 2022 8:23am
marcochezzi
Chris
Chris I am in your debt..
JLR quoted me the equivalent of £50.00 plus 21 working days to get one over the pond since there is nothing locally available..
Control cable manufacturer took one look at it, told me to come back 2.5 hours later to collect new item, £4.00 all in..
Can hardly argue that, was an absolute pleasure, now to fit it all back..
Post #632955 26th May 2022 2:11pm
Kot
Buy 2 if 1 has failed the other could be next Rolling with laughter 2018 SE SDV8 4.4 Byron Blue
Post #632956 26th May 2022 2:13pm
absolute bargain..well done.. Thumbs Up ... - .- -.
Post #632958 26th May 2022 2:46pm
marcochezzi
Cannot really, the big pretty silvery thing needs to have the cable go through it, so can only be re-used once she snaps, and they are directional, so cannot fit on either side of the tailgate..
Post #632962 26th May 2022 3:29pm
marcochezzi
Yep, hobby of mine, Tim the toolman..
Was getting ready to do a small boring job for a friend, this is my setup, purely hobby nothing work related in here..
Post #633025 27th May 2022 2:50am
Nice. You should post it up in the Garage Workshop thread.
Post #633050 27th May 2022 9:15am
Bigfella70
United Kingdom 2016 Range Rover Vogue SE SDV8 Santorini Black
Interesting thread thanks for sharing!
I was wondering the other day what the load weight limit on the lower tailgate actually is?
Compared to the L322 I was quite surprised at how fragile the L405 lower tailgate cables look on my new to me 405! Current
2016 MY L405 SDV8
2018 VW Golf GT EVO
2001 BMW Z3 2.2
Previous
2002 L322 TD6
2004 Mercedes R230 SL350
1994 993 Carrera
Range Rover P38 x3
Range Rover 3.9 EFI
Post #633205 30th May 2022 6:20am
