Home > Maintenance & Mods (L405) > Damn, guess I need to lose some weight....
marcochezzi
South Africa 2011 Range Rover Vogue SE 5.0 SC V8 Fuji White
Bigfella70 wrote:
Interesting thread thanks for sharing!
I was wondering the other day what the load weight limit on the lower tailgate actually is?
Compared to the L322 I was quite surprised at how fragile the L405 lower tailgate cables look on my new to me 405!
Seems to be 440Lbs, 200kg.. Thumbs Up
Post #633229 30th May 2022 11:09am
tomiRR
2013 Range Rover Vogue TDV6 Aleutian Silver
Dear Marcochezzi,
Can you tell me the exact name and number of this part?
My cable's coating gone by the ages, and now the metal tunnel meets directly with the metal cable.
Some of its wires already spined up by the rub, so the situation could be the same to your system.
Since I don't have opportunity and knowledge to disassemble the lower tailgate myself, I need to rely on some profession. I just want to know what is the part to replace and where I can get it the cheapest.
Thank you in advance!
Tom
Post #710529 29th Jan 2025 1:09pm
marcochezzi
Hi Tom
Sadly I cannot help with a part number, I had a cabling company manufacture a new cable for me..
Maybe someone else on this forum can help, just bear in mind that if you are going to purchase a new unit from JLR, the left and right hand cable assemblies will have different part numbers as they are not an identical pair..
Good luck..
Post #710534 29th Jan 2025 1:46pm
tomiRR
Dear Marcochezzi,
Thank you for your answer and taking my attention on side-differences.
During time, after some research, I found the part:
Lower tailgate cable stay LEFT: LR034439
Lower tailgate cable stay RIGHT: LR034438
Have a nice day!
Tom Smile
Post #710535 29th Jan 2025 1:49pm
Stick Legs
United Kingdom 2015 Range Rover Vogue SE SDV8 Causeway Grey
I always thought that the L405 cable was just to retract the tailgate and that the hinge acted to stop it moving past the horizontal.
Those little wires really don't look up to it do they! 2015 SDV8 L405
1996 TVR Griffith 500
Post #712750 25th Feb 2025 10:01am
