![]() | Home > Maintenance & Mods (L322) > Automatic Headlights |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35650 ![]() ![]() |
turn the light knob to number 4,
chris_read Member Since: 26 Feb 2012 Location: Louth, Lincolnshire Posts: 474 ![]() ![]() ![]() |
And if that doesn’t work, you may have the ‘auto lights and wipers’ wiring fault which has been experienced by a few of us. 2017 Jaguar F Pace 25t Portfolio - still part of the JLR family 😀
madnessgonemad Member Since: 28 Aug 2020 Location: Kent Posts: 105 ![]() ![]() |
Thank you, but I have no position 4.
brian1951 Member Since: 07 Nov 2015 Location: Salop Posts: 275 ![]() ![]() |
It is standard on 2012 Westminsters. Yours must of been replaced. |
I couldn’t find the spec of Westminsters anywhere. Thanks. I will remove my switch and hope to find a couple of wires going nowhere. |
mjdronfield Member Since: 04 Nov 2011 Location: Derbyshire Posts: 7911 ![]() ![]() ![]() |
Standard according to this….
Brilliant, thanks. There in black and white! I can only assume that someone has replaced the original with the wrong switch.
As you say, hopefully a quick look behind the switch will reveal all….. or not… and you will be more confused….
I’ve seen a YouTube about removing the end dash panel to get at the switch. Looking at a picture of a switch it looks like you can remove it separately if you are careful. Has anyone done this or do you have to take the whole panel off?
The Workshop Manual is available in the Wiki… top right under the fullfatrr banner. Should be in there.
JMC Member Since: 01 Feb 2009 Location: Aberdeen-Angus Posts: 780 ![]() ![]() ![]() |
My 08MY Vogue had auto lights and my 12MY Westminster certainly has them. I'd be very surprised if all FFRR's didn't have this feature after about 2007. |
Update.
Ah, I remember the posts with those broken wires on now, think they caused other problems too.
Very satisfying to sort it out! |
