Home > Maintenance & Mods (L322) > Automatic Headlights
madnessgonemad
Afternoon all.
I have had my Westminster 2012 for a couple of weeks now so am getting used to the gadgets. Really like the cooled seats. Sound is good if you turn the vol up. TV quite fun.
However I am very surprised that there are no automatic lights. I know this is a ten year old car but I took it for granted that it would have them. My 2003 XK8 has them!
My question is; Is it possible to retrofit this? I even thought the wiring might be present behind the current manual switch.
Any help appreciated. I really miss the feature
Post #632879 25th May 2022 3:47pm
turn the light knob to number 4,
Post #632880 25th May 2022 4:18pm
chris_read
England 2009 Range Rover Vogue TDV8 Stornoway Grey
And if that doesn’t work, you may have the ‘auto lights and wipers’ wiring fault which has been experienced by a few of us. 2017 Jaguar F Pace 25t Portfolio - still part of the JLR family 😀
2009 3.6 V8 (MY2010) - my first ever diesel! - now also gone Sad
2004 4.4 V8 Petrol Vogue - now gone
Post #632885 25th May 2022 5:01pm
madnessgonemad
Thank you, but I have no position 4.
Previous car is a Freelander which had the auto lights on position 4 as on your picture.
I can’t believe this wasn’t standard on all models. Unless it has been replaced for some reason with an old switch.
Auto wipers are present and seem to work
Post #632888 25th May 2022 5:16pm
brian1951
2012 Range Rover Westminster 4.4 V8 Orkney Grey
It is standard on 2012 Westminsters. Yours must of been replaced.
Post #632890 25th May 2022 6:12pm
madnessgonemad
I couldn’t find the spec of Westminsters anywhere. Thanks. I will remove my switch and hope to find a couple of wires going nowhere.
Post #632891 25th May 2022 6:17pm
mjdronfield
Standard according to this….
 2011 Range Rover Vogue SE 4.4 TDV8
Previous cars :
2003 Range Rover Vogue TD6
1999 Discovery Td5 ES
1995 BMW M5 3.8 6 speed
1992 BMW M5 3.8
1988 BMW 735i SE
1989 Ford Sierra XR4x4 2.9i
1981 Ford Fiesta Supersport
Post #632894 25th May 2022 6:44pm
madnessgonemad
Brilliant, thanks. There in black and white! I can only assume that someone has replaced the original with the wrong switch.
Cheers
Post #632895 25th May 2022 6:59pm
mjdronfield
As you say, hopefully a quick look behind the switch will reveal all….. or not… and you will be more confused….
Previous cars :
1992 BMW M5 3.8
1988 BMW 735i SE
Post #632896 25th May 2022 7:05pm
madnessgonemad
I’ve seen a YouTube about removing the end dash panel to get at the switch. Looking at a picture of a switch it looks like you can remove it separately if you are careful. Has anyone done this or do you have to take the whole panel off?
Thanks
Post #632930 26th May 2022 7:25am
mjdronfield
The Workshop Manual is available in the Wiki… top right under the fullfatrr banner. Should be in there.
Previous cars :
1992 BMW M5 3.8
1988 BMW 735i SE
Post #632934 26th May 2022 8:48am
JMC
Scotland 2012 Range Rover Westminster TDV8 Orkney Grey
My 08MY Vogue had auto lights and my 12MY Westminster certainly has them. I'd be very surprised if all FFRR's didn't have this feature after about 2007. Confused The older I get, the more I realise that people confuse wrinkles for wisdom Smile
Post #632987 26th May 2022 7:11pm
madnessgonemad
Update.
Switch upgraded. Headlights and Wipers not working on auto so realised I must have the wiring fault. Sorted it in a couple of hours with the help of the forum history. Very easy to do so now very chuffed. A bit daunting to start with but located the broken wires very quickly. Did not have to take the seats out just loosened back bolts and removed front ones and tilted back the seat.
It’s great this forum!
Post #633200 29th May 2022 10:00pm
mjdronfield
Ah, I remember the posts with those broken wires on now, think they caused other problems too.
Guessing a previous owner changed the switch, rather than manage to fix the fault.
Excellent result.
Previous cars :
1992 BMW M5 3.8
1988 BMW 735i SE
Post #633201 29th May 2022 10:14pm
madnessgonemad
Very satisfying to sort it out!
Post #633202 29th May 2022 10:22pm
