Home > Maintenance & Mods (L322) > Automatic Headlights |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35435 |
turn the light knob to number 4,
25th May 2022 4:18pm |
chris_read Member Since: 26 Feb 2012 Location: Louth, Lincolnshire Posts: 473 |
And if that doesn’t work, you may have the ‘auto lights and wipers’ wiring fault which has been experienced by a few of us. 2017 Jaguar F Pace 25t Portfolio - still part of the JLR family 😀
25th May 2022 5:01pm |
madnessgonemad Member Since: 28 Aug 2020 Location: Kent Posts: 104 |
Thank you, but I have no position 4.
25th May 2022 5:16pm |
brian1951 Member Since: 07 Nov 2015 Location: Salop Posts: 275 |
It is standard on 2012 Westminsters. Yours must of been replaced. |
25th May 2022 6:12pm |
I couldn’t find the spec of Westminsters anywhere. Thanks. I will remove my switch and hope to find a couple of wires going nowhere. |
25th May 2022 6:17pm |
mjdronfield Member Since: 04 Nov 2011 Location: Derbyshire Posts: 7840 |
Standard according to this….
25th May 2022 6:44pm |
Brilliant, thanks. There in black and white! I can only assume that someone has replaced the original with the wrong switch.
25th May 2022 6:59pm |
As you say, hopefully a quick look behind the switch will reveal all….. or not… and you will be more confused….
25th May 2022 7:05pm |
I’ve seen a YouTube about removing the end dash panel to get at the switch. Looking at a picture of a switch it looks like you can remove it separately if you are careful. Has anyone done this or do you have to take the whole panel off?
26th May 2022 7:25am |
The Workshop Manual is available in the Wiki… top right under the fullfatrr banner. Should be in there.
26th May 2022 8:48am |
JMC Member Since: 01 Feb 2009 Location: Aberdeen-Angus Posts: 768 |
My 08MY Vogue had auto lights and my 12MY Westminster certainly has them. I'd be very surprised if all FFRR's didn't have this feature after about 2007. The older I get, the more I realise that people confuse wrinkles for wisdom |
26th May 2022 7:11pm |
Update.
29th May 2022 10:00pm |
Ah, I remember the posts with those broken wires on now, think they caused other problems too.
29th May 2022 10:14pm |
Very satisfying to sort it out! |
29th May 2022 10:22pm |
