Home > Maintenance & Mods (L405) > Air Con Packed Up
Ragingrover
United Kingdom 2014 Range Rover Autobiography SDV8 Nara Bronze
Air Con Packed Up
Rather typical I took a 280 mile round trip today in the lovely sunshine and noticed no air con.... I mean non, not weak, nothing but lovely fan assisted hot air from outside, bummer.
I've checked as best as I can and beleive there is still pressure in the system (old DIY recharge canister with pressure gauge, yes I know !!)
So before I book it into the garage for investigation/fix, is there any common issue on these that I can help and point them too first ?
Thanks
Post #632014 17th May 2022 5:44pm
Weegie
Worth going for a recharge. They should check the system for leaks in the first stage, then, if none, recharge. Normlly there is no cost if they do not get it recharged.
If it has not previously had a recharge, at 8 years old it would not be unreasonable to suppose it needs one, John
GAP iiD BT
Post #632017 17th May 2022 5:48pm
DrRob
Is it a 4.4 tdv8?
If yes, a valve on the compressor fails. Fix is a new compressor. Use Advanced Factors for a non Genuine OEM one Gone to a good home: 2011 4.4 TDV8 Vogue SE Buckingham Blue with Ivory and clear glass = "Rory"
Post #632018 17th May 2022 5:51pm
Andy S
United Kingdom 2015 Range Rover Vogue SE SDV8 Aintree Green
A failed valve means a new compressor Shocked
Post #632019 17th May 2022 5:54pm
Ragingrover
DrRob wrote:
Is it a 4.4 tdv8?
It's a SDV8 but whether the compressor is different from one to the other who knows...well JLR do obviously lol
Post #632022 17th May 2022 6:06pm
Swasher
United Kingdom 2017 Range Rover Vogue SE SDV8 Corris Grey
Am I right in thinking if his compressor has failed that the Fridge unit under arm rest and Air Suspension would've failed too..? MY17 VSE FF Corris
Post #632023 17th May 2022 6:07pm
Ragingrover
I would tend to agree, just my DIY guage shows very healthy pressure, I know it's far from perfect but I've known AC systems work down to quite low pressures before giving up the shost due to the pressure switch cutting comp clutch out
Post #632024 17th May 2022 6:09pm
Ragingrover
The fridge does still work thank god.... and I had the very same thought
Post #632026 17th May 2022 6:13pm
West Yorks V8
I had a similar issue….after a trip to the specialist with the right kit and gas….all is good, and Ice Cold Air Con. Given the special gas, it is a garage job, and is expensive, but absolutely worth it.
Hope it’s something simple, keep us updated.
 Range Rover 4.4 SDV8 Autobiography
Land Rover Freelander 2 SD4
Range Rover P38 4.6
Range Rover Classic LSE 4.2 x 2
Range Rover Classic 3.9
Range Rover Classic 3.5
Post #632394 20th May 2022 10:03pm
Phoenix
Refrigerant pressure varies with temperature, it's possible you (and the pressure sensor) see enough pressure for the system to run but there isn't enough refrigerant to create the required pressure differential to cool the vehicle.
The only way is to recover the refrigerant and compare the quantity recovered to the specification. If it's low, then the leak needs to be found as it's illegal to refill a known or suspected leaking refrigerant system (although a lack of enforcement means very few tech's care either way).
Post #632404 21st May 2022 5:42am
Ragingrover
Well it was something pretty simple, punctured condenser. New genuine one fitted, not straight forward, system regas and £650 lighter, job done.
Post #632427 21st May 2022 11:45am
Tis very expensive gas in the 405's... Be warned Shocked
Post #632461 21st May 2022 5:14pm
Ragingrover
The gas cost was £100 ish but the bumper having to come off and on is what caused the swearing… so the receptionist told me 😂😂
Post #632463 21st May 2022 5:18pm
Phoenix
We're finding R134A is getting more expensive due to production being shifted to R1234YF, currently awaiting delivery of a R744 (CO2) machine, 9.5kg is over £700 - for something seen as an unwanted waste product...
Post #632468 21st May 2022 6:00pm
V8Noise
United Kingdom 2017 Range Rover Autobiography 5.0 SC V8 Carpathian Grey
Mine goes into ATS next Thursday. Via Groupon the expensive gas will be £89.99. At least it'll be nice and cold then. 5 years old so it's about time I guess. 2017 5.0 Autobiography Supercharged
2005 Merc SL350
2005 Disco HSE 2.7 oil burner
Post #632507 22nd May 2022 7:06am
