![]() | Home > Maintenance & Mods (L405) > Air Con Packed Up |
Weegie Member Since: 09 Jun 2014 Location: East Sussex Posts: 3244 ![]() ![]() ![]() |
Worth going for a recharge. They should check the system for leaks in the first stage, then, if none, recharge. Normlly there is no cost if they do not get it recharged.
DrRob Member Since: 16 Apr 2015 Location: Petersfield, Hampshire Posts: 4318 ![]() ![]() ![]() |
Is it a 4.4 tdv8?
Andy S Member Since: 16 Jun 2013 Location: Sevenoaks Posts: 1041 ![]() ![]() ![]() |
A failed valve means a new compressor |
Ragingrover Member Since: 05 Oct 2019 Location: Malvern Posts: 152 ![]() ![]() ![]() |
It's a SDV8 but whether the compressor is different from one to the other who knows...well JLR do obviously lol |
Swasher Member Since: 03 Nov 2021 Location: Suffolk Posts: 16 ![]() ![]() ![]() |
Am I right in thinking if his compressor has failed that the Fridge unit under arm rest and Air Suspension would've failed too..? MY17 VSE FF Corris |
I would tend to agree, just my DIY guage shows very healthy pressure, I know it's far from perfect but I've known AC systems work down to quite low pressures before giving up the shost due to the pressure switch cutting comp clutch out |
The fridge does still work thank god.... and I had the very same thought |
West Yorks V8 Member Since: 25 May 2020 Location: West Yorkshire Posts: 43 ![]() ![]() |
I had a similar issue….after a trip to the specialist with the right kit and gas….all is good, and Ice Cold Air Con. Given the special gas, it is a garage job, and is expensive, but absolutely worth it.
Refrigerant pressure varies with temperature, it's possible you (and the pressure sensor) see enough pressure for the system to run but there isn't enough refrigerant to create the required pressure differential to cool the vehicle.
Well it was something pretty simple, punctured condenser. New genuine one fitted, not straight forward, system regas and £650 lighter, job done. |
Tis very expensive gas in the 405's... Be warned |
The gas cost was £100 ish but the bumper having to come off and on is what caused the swearing… so the receptionist told me 😂😂 |
We're finding R134A is getting more expensive due to production being shifted to R1234YF, currently awaiting delivery of a R744 (CO2) machine, 9.5kg is over £700 - for something seen as an unwanted waste product... |
V8Noise Member Since: 25 Apr 2015 Location: Dereham Posts: 424 ![]() ![]() ![]() |
Mine goes into ATS next Thursday. Via Groupon the expensive gas will be £89.99. At least it'll be nice and cold then. 5 years old so it's about time I guess. 2017 5.0 Autobiography Supercharged
