Home > Technical (L322) > No ABS, HDC, DSC, suspension lowered 2007 L322 TDV8 |
Merchy Member Since: 14 Feb 2021 Location: North Wales Posts: 1181 |
https://www.fullfatrr.com/forum/topic2582....bs+hdc+dsc
14th May 2022 11:23am |
Mitch2312 Member Since: 14 May 2022 Location: Berkshire Posts: 5 |
Hi Merchy
14th May 2022 1:35pm |
One more thought, this is most likely a long shot, try a hard reset on the battery terminals, there will be info about this in various threads, may be worth a go, and it won't cost you a penny.
14th May 2022 2:54pm |
GraemeS Member Since: 06 Mar 2015 Location: Wagga area Posts: 2469 |
Have you read the fault codes from the ABS module prior to switching off the ignition? |
14th May 2022 8:42pm |
Graeme5,
15th May 2022 9:47am |
Graeme5
16th May 2022 12:49pm |
I suggest that you test with one of the non-genuine sensors disconnected at a time to see what faults that produces. Hall effect sensors detect the direction of travel of the passing trigger and the RR's ABS ecu checks the wheel direction so a non-genuine sensor might not operate with this capability.
16th May 2022 9:20pm |
Do you have the original LR sensors still? refit one at a time to the rear and see if the fault clears, that DTC definitely points to a rotation plausibility error. WRT the battery disconnect, other than for welding / plasma cutting, I've never seen any manufacturer instruct that the battery leads are connected together as a means of carrying out any kind of reset. |
16th May 2022 9:36pm |
Hi
17th May 2022 8:10am |
My guess is that the ABS ecu provides the data unsigned to diagnostics rather than the diagnostic tool not showing the sign. It's a short-coming that the fault code doesn't identify the particular sensor. |
17th May 2022 10:14am |
For welding I disconnect the battery then ground the positive lead to provide a good and hopefully shortest earth path for any voltage that finds its way into the 12V power. |
17th May 2022 10:18am |
