![]() | Home > Technical (L322) > No ABS, HDC, DSC, suspension lowered 2007 L322 TDV8 |
Merchy Member Since: 14 Feb 2021 Location: North Wales Posts: 1214 ![]() ![]() ![]() |
https://www.fullfatrr.com/forum/topic2582....bs+hdc+dsc
Mitch2312 Member Since: 14 May 2022 Location: Berkshire Posts: 5 ![]() ![]() ![]() |
Hi Merchy
One more thought, this is most likely a long shot, try a hard reset on the battery terminals, there will be info about this in various threads, may be worth a go, and it won't cost you a penny.
GraemeS Member Since: 06 Mar 2015 Location: Wagga area Posts: 2561 ![]() ![]() ![]() |
Have you read the fault codes from the ABS module prior to switching off the ignition? |
Graeme5,
Graeme5
I suggest that you test with one of the non-genuine sensors disconnected at a time to see what faults that produces. Hall effect sensors detect the direction of travel of the passing trigger and the RR's ABS ecu checks the wheel direction so a non-genuine sensor might not operate with this capability.
Do you have the original LR sensors still? refit one at a time to the rear and see if the fault clears, that DTC definitely points to a rotation plausibility error. WRT the battery disconnect, other than for welding / plasma cutting, I've never seen any manufacturer instruct that the battery leads are connected together as a means of carrying out any kind of reset. |
Hi
My guess is that the ABS ecu provides the data unsigned to diagnostics rather than the diagnostic tool not showing the sign. It's a short-coming that the fault code doesn't identify the particular sensor. |
For welding I disconnect the battery then ground the positive lead to provide a good and hopefully shortest earth path for any voltage that finds its way into the 12V power. |
