Transfer case issue or transmission?Mechanical / electrical? | |
I have an issue with either transfer case or transmission... i would really appreciate any ideas if anyone observed anything similar or have had similar experience.
The car is 2011, 4.4 TDV8. ZF8 gearbox. Very low mileage.
Error state is:
- car is only able to move about a meter or so, before it starts vibrating and stops due to what it feels like mechanical restriction from transfer case. Reason i point to transfer case is that when I lay on the ground and ignition is switched off, you can hear loud clanking noise(solenoid pulls back the fork). What results in kind of unlocking the mechanical restriction and car is able to move freely again. (for another meter)
- only one fault is set with this condition; transmission control module P279D-02(Four Wheel Drive Range Circuit)
I am able to make the car drive normally, when i disconnect TC solenoid completely. In this instance there is additional fault to the one above with transfer case P181B-00 Clutch Actuator Changeover Solenoid - Low. What makes sense as it is disconnected.
Question is, why is solenoid, when connected causing the mechanical restriction and only releases it when ignition is switched off - clunks loudly or when disconnected entirely?
Is the solenoid working against the clutches incorrectly? As normally it should only disangage clutch in TC when there is demand for range change. Right?
Any help would be much appreciated.
