Home > Technical (L322) > Transfer case issue or transmission?Mechanical / electrical?
krzysmaxi
United Kingdom 2011 Range Rover SE TDV8 Alaska White
I have an issue with either transfer case or transmission... i would really appreciate any ideas if anyone observed anything similar or have had similar experience.
The car is 2011, 4.4 TDV8. ZF8 gearbox. Very low mileage.
Error state is:
- car is only able to move about a meter or so, before it starts vibrating and stops due to what it feels like mechanical restriction from transfer case. Reason i point to transfer case is that when I lay on the ground and ignition is switched off, you can hear loud clanking noise(solenoid pulls back the fork). What results in kind of unlocking the mechanical restriction and car is able to move freely again. (for another meter)
- only one fault is set with this condition; transmission control module P279D-02(Four Wheel Drive Range Circuit)
I am able to make the car drive normally, when i disconnect TC solenoid completely. In this instance there is additional fault to the one above with transfer case P181B-00 Clutch Actuator Changeover Solenoid - Low. What makes sense as it is disconnected.
Question is, why is solenoid, when connected causing the mechanical restriction and only releases it when ignition is switched off - clunks loudly or when disconnected entirely?
Is the solenoid working against the clutches incorrectly? As normally it should only disangage clutch in TC when there is demand for range change. Right?
Any help would be much appreciated.
Post #630809 6th May 2022 5:26pm
DrRob
Get it to Martin Hind at Dartford Transmissions and Autocare. He's your guru.
Job done Gone to a good home: 2011 4.4 TDV8 Vogue SE Buckingham Blue with Ivory and clear glass = "Rory"
Post #630811 6th May 2022 5:30pm
Ffrr-lover
United Kingdom 2012 Range Rover Vogue SE 4.4 V8 Santorini Black
+1 for Martin. He knows his biscuits!!! Currently driving: 2012 L322 SE Overfinch 4.4 tdv8
Past rides:
2014 Audi Q7 3.0d (good riddance)
2010 L322 Autobiography 5.0 Supercharged
2011 L320 HSE 3.0 sdv6
2014 Jaguar XF-RS 5.0 supercharged
2007 BMW 535D
2005 Mini Cooper S
https://www.fullfatrr.com/forum/topic59478.html
Post #630817 6th May 2022 7:32pm
GraemeS
Maybe the TC motor simply needs to be recalibrated using a suitable diagnostic tool.
Post #630835 6th May 2022 9:24pm
RRPhil
The solenoid is normally powered ‘on’ so that the shift fork engages clutch-control mode by default. When disconnected, the spring-loaded solenoid plunger will pull the shift fork to the low/high range change mode position. In both positions, it’s the shift motor that does the work i.e. either applying the clutch or performing the range change. The solenoid just selects which one.
Even if there were an issue with the clutch control, you would imagine that the worse that could happen would be that the clutch ended up locked solid. This would just engage 4WD with the centre differential locked, so I don’t see why this would stop the vehicle moving.
There’s obviously more to it than this, as something is getting locked to the casing somehow – presumably due to a mechanical failure. Unfortunately, I don’t think you have any choice other than to strip the transfer case to find it.
https://www.fullfatrr.com/forum/topic12404.html
Certainly not a common issue. The DD295 transfer case was first used in the L322 for 2006MY and was carried over into the L405 due to its reliability.
Phil
Post #630896 7th May 2022 1:17pm
