Home > Technical (L322) > Brake fluid change
dhallworth
I'm reluctant to clamp brake hoses now as I've had problems with them in the past after the clamp has been removed.
On mine I tried a nut and bolt with a copper washer either side but they didn't seal. 2002 4.6 Vogue SE - Alveston Red with Lightstone Leather
Post #629222 20th Apr 2022 2:16pm
knwatkins
I tried exactly that too David but like you, it didn't seal and I ended up losing the brake fluid.
One of the chaps I work with wedged his brake pedal in the down position thereby causing a vacuum in the lines so the fluid didn't leak out. A good idea which I'll probably try next time. Kev
2014 L405 RR Vogue SE 4.4 SDV8 in Corris Grey
2010 L320 RRS HSE 3.0 TDV6 in Stornoway Grey
Post #629228 20th Apr 2022 3:06pm
Goldstar
2011 Range Rover Autobiography TDV8 Stornoway Grey
When I replaced the rear nearside caliper, I let gravity do the work for me. Worked a treat. Took about 15 minutes. I wasn't in a rush so it worked just fine for me
Post #629230 20th Apr 2022 3:53pm
Caesium wrote:
The ABS circuit is the same circuit as the service brakes. All the ABS pump does, is interrupt the pressure to the wheel that has lost traction.
Maybe I need to correct my wording. Firstly, to bleed you can do it in the usual way. To flush, I think you should follow the correct procedure.
This a L322 brake diagram.
The ABS module is on the same circuit, but there are internal reserviours that are not a part of the primary brake circuit and are only opened to the rest of the circuit when the ABS is active. This fluid will not get changed if you just bleed the brakes in the conventional way.
Now, I haven't changed the brake fluid on my Range Rover, so am more than happy to be corrected. I have changed the brake fluid of the ABS brakes of my motorcycles and you have to bleed them, get the ABS pump to flush out the old fluid, then bleed them again if you want to replace the brake fluid across the system. From my understanding the Range Rover system requires a similar procedure for flushing.
Post #629235 20th Apr 2022 5:19pm
Davlyn
United Kingdom 2012 Range Rover Westminster 4.4 V8 Baltic Blue
knwatkins wrote:
I use one of these when bleeding or flushing the brake fluid...
https://www.amazon.co.uk/Sealey-VS820-Clut...B000ROARTI
I find it's much easier on my ears as I don't have to put up with the wife moaning that her leg is aching!
Highly recommended.
That looks like a Bobby Dazzler. Most certainly ordering one of those. Love buying more tools…
Post #629253 20th Apr 2022 8:19pm
Nylands
United Kingdom 2012 Range Rover Westminster TDV8 Zambezi Silver
Brake flushing on L322
Hi Davlyn
I've just bought that pressure vessel from amazon. Did you find it worked well without ant issues and would two litres in it be enough etc?
regards
Dave Whistle
Post #703650 3rd Nov 2024 11:54am
JayGee
Like the fact that it's a 1 man operation and doesn't need an airline from a compressor. 2012 TDV8 Vogue (L322)
Post #703665 3rd Nov 2024 2:41pm
kevinp
I bought one of them and it worked a treat the first time.
Came to use it a year later and all the seals were shot.
Bought this one which is very good but you need an air compressor.
Post #703671 3rd Nov 2024 3:13pm
