Home > In Car Electronics (L405) > Landrover Dashcam |
Tinman Member Since: 22 Mar 2017 Location: kent Posts: 1194 |
If it's the Land Rover camera, it may not have been set up correctly on the App
3rd Sep 2024 8:29am |
Bagus Member Since: 14 Apr 2014 Location: London Posts: 197 |
Tackled installing this today. The front camera was simple enough although with a pan roof there is all room in the overhead console. Found that using a long cable tie was easier than a ruler when threading to front cam although I did have to unscrew the backing plate that surrounds the plug I order to fit it through the headlining..
12th Oct 2024 9:04pm |
Phil. Member Since: 19 Apr 2010 Location: West Midlands Posts: 787 |
Some hints and pics here as to how to fix the rear cam. Good luck.
12th Oct 2024 9:25pm |
Thanks. Thought I was done with PITA jobs as I fitted deployable side steps last weekend. Looks like the rear camera is going to be more challenging than first thought. 2016 5.0 Loire Blue
12th Oct 2024 9:34pm |
Andy355 Member Since: 21 Nov 2017 Location: London Posts: 45 |
I have a new AB hybrid with this fitted but don’t really understand how to connect. If in the car I can connect phone to camera via WiFi/bluetooth as it will prompt me to connect but as soon as leave vehicle and connect to another WiFi network I can’t access the camera. That’s almost always immediate as need to access WiFi to start charging. I presume cam is recording onto SD card but the useful features such as live view I can’t use unlesss I sort this. Any ideas? I should go back to dealer but not local |
10th Dec 2024 9:48pm |
MJG Member Since: 08 Mar 2022 Location: Melbourne Posts: 32 |
I had a Landrover VPLKV0134 Dashcam fitted in my 2022 Range Rover AB worked ok, I have just purchased a 2024 Range Rover SV and reading that the VPLKV0134 is not compatible!! Is this true or false?
12th Dec 2024 10:51am |
