Home > In Car Electronics (L405) > Landrover Dashcam
Page 3 of 3 <123
Big Vee
United Kingdom 2019 Range Rover Autobiography SDV8 Corris Grey
Dash cam
Hello group, just fitted my camera I purchased from Ebay, £305 brand new. Its a 20my AB I didn't follow the fitting instructions as per the site at the rear of car, getting the cable from car to boot lid was the worst bit, managed to mouse the cable through rubber boot ( used proper pulling lube ) removing wiper motor cover to feed cable through drilled hole at the top, I've read some fitted at btm, ran out of time to tomorrow ill position both cameras, took the opportunity to adjust the spoiler so it didn't touch plastic trim. App works fine on my android phone with live view and download of footage.
Post #699354 2nd Sep 2024 10:35pm
Tinman
United Kingdom 2017 Range Rover Autobiography SDV8 Silicon Silver
If it's the Land Rover camera, it may not have been set up correctly on the App
There is a good YouTube from Powerfuluk for setting it up. 2017 SDV8 4.4 silicon silver AB
2012 TDV8 4.4 Stornaway Grey AB
2011 TDV8 4.4 Buckingham Blue
2012 VW V6 3.0 Tougreg
Post #699373 3rd Sep 2024 9:29am
Bagus
United Kingdom 2016 Range Rover Autobiography 5.0 SC V8 Loire Blue
Tackled installing this today. The front camera was simple enough although with a pan roof there is Censored all room in the overhead console. Found that using a long cable tie was easier than a ruler when threading to front cam although I did have to unscrew the backing plate that surrounds the plug I order to fit it through the headlining..
For the rear is it better to thread down the A pillar and along the floor or go along the headlining?
Plan to mount the rear camera at the base of the window (if that makes a difference re length of the cable). 2016 5.0 Loire Blue
2002 4.4 v8 Adriatic Blue
Post #702088 12th Oct 2024 10:04pm
Phil.
Some hints and pics here as to how to fix the rear cam. Good luck.
https://www.fullfatrr.com/forum/topic55841.html?highlight=dashcam MY23 D350 HSE
On my 7th RR plus various other JLR vehicles
Post #702090 12th Oct 2024 10:25pm
Bagus
Thanks. Thought I was done with PITA jobs as I fitted deployable side steps last weekend. Looks like the rear camera is going to be more challenging than first thought. 2016 5.0 Loire Blue
Post #702091 12th Oct 2024 10:34pm
Andy355
United Kingdom 2016 Range Rover Vogue SE SDV8 Santorini Black
I have a new AB hybrid with this fitted but don’t really understand how to connect. If in the car I can connect phone to camera via WiFi/bluetooth as it will prompt me to connect but as soon as leave vehicle and connect to another WiFi network I can’t access the camera. That’s almost always immediate as need to access WiFi to start charging. I presume cam is recording onto SD card but the useful features such as live view I can’t use unlesss I sort this. Any ideas? I should go back to dealer but not local
Post #706568 10th Dec 2024 10:48pm
MJG
Australia 2019 Range Rover Autobiography SDV8 Corris Grey
I had a Landrover VPLKV0134 Dashcam fitted in my 2022 Range Rover AB worked ok, I have just purchased a 2024 Range Rover SV and reading that the VPLKV0134 is not compatible!! Is this true or false?
If true any recommendations for front and rear cameras (hard wired) ideally without battery backup .
Thanks
Post #706679 12th Dec 2024 11:51am
Page 3 of 3 <123
