Home > Wheels & Tyres > Tyre pressures
supershuttle
Tyre pressures
I noticed that my front tyres were under inflated- they were ! So I inflated to 33 psi with my airline BUT when I checked with my cheapo Chinese digital job it said 41.5psi what do others use and are the ones you pay for calibrated? Geoff
Post #627612 2nd Apr 2022 4:12pm
mjdronfield
I use a hand held digital one. Think it might have been from Halfords years ago. No idea if it’s calibrated, but have never had uneven tyre wear from using it on various cars, so I top up air with whatever device…. And then check with that finally.
Might be wrong… but it’s consistent 🤣
Previous cars :
2003 Range Rover Vogue TD6
1999 Discovery Td5 ES
1995 BMW M5 3.8 6 speed
1992 BMW M5 3.8
1988 BMW 735i SE
1989 Ford Sierra XR4x4 2.9i
1981 Ford Fiesta Supersport
Post #627615 2nd Apr 2022 4:39pm
appj62
England 2006 Range Rover Vogue SE 4.2 SC V8 Buckingham Blue
Use a handheld dial indicator type. Pretty consistent with digital indicator on electric inflators. Foot pump gauge is out by as much as 10 psi at times. Garage forecourt indicators are woeful. Previous cars:
S-Max 2007-2013 (only diesel I've had, good car but expensive when diesely bits go wrong, so what's the point?)
Galaxy 2001-2007
Mondeo Estate 1997-2001
Sierra Estate 1993-1997
Uno Turbo 1987 -1993
Fiesta 1984 - 1987
Fiat 127 1982 - 1984
Post #627620 2nd Apr 2022 6:23pm
littlecub
Australia 2003 Range Rover HSE Td6 Epsom Green
I had some slow leaks on both front and rear left tyres these last few months.
When they started to go down rapidly overnight thats when I got them fixed up.
The cheap and nasty gauges were useless,so I bought a Michelin tyre gauge MN 4203.
Easy to use and accurate. Thumbs Up
Post #627625 2nd Apr 2022 7:46pm
gettingold
I use either the ring compressor or my local garage. But I set them using my draper pencil gauge. Like others, even tyre wear and it feels right so I trust it. visiting from www.rrsport.co.uk
Post #627629 2nd Apr 2022 9:21pm
will308f
United Kingdom 2014 Range Rover Autobiography SDV8 Loire Blue
ive used a ring compressor for years ..lots better than supermarket ones i think
Post #629848 27th Apr 2022 7:17am
Kot
I use a ring compressor run off the 12v supply the gauge is within a few psi accuracy but rely on the TPMS for accurate readings 2018 SE SDV8 4.4 Byron Blue
Post #629859 27th Apr 2022 8:31am
DrRob
Toolstation sell a nice digital pressure gauge which I use to check after using a 240V Michelin compressor Gone to a good home: 2011 4.4 TDV8 Vogue SE Buckingham Blue with Ivory and clear glass = "Rory"
Post #629864 27th Apr 2022 9:05am
