![]() | Home > Wheels & Tyres > Tyre pressures |
supershuttle Member Since: 20 Mar 2011 Location: Lancashire Posts: 3858 ![]() ![]() ![]() |
I noticed that my front tyres were under inflated- they were ! So I inflated to 33 psi with my airline BUT when I checked with my cheapo Chinese digital job it said 41.5psi what do others use and are the ones you pay for calibrated? Geoff |
mjdronfield Member Since: 04 Nov 2011 Location: Derbyshire Posts: 7851 ![]() ![]() ![]() |
I use a hand held digital one. Think it might have been from Halfords years ago. No idea if it’s calibrated, but have never had uneven tyre wear from using it on various cars, so I top up air with whatever device…. And then check with that finally.
appj62 Member Since: 07 Aug 2013 Location: Cheshire Posts: 424 ![]() ![]() ![]() |
Use a handheld dial indicator type. Pretty consistent with digital indicator on electric inflators. Foot pump gauge is out by as much as 10 psi at times. Garage forecourt indicators are woeful. Previous cars:
gettingold Member Since: 03 Apr 2018 Location: Wiltshire Posts: 285 ![]() ![]() |
I use either the ring compressor or my local garage. But I set them using my draper pencil gauge. Like others, even tyre wear and it feels right so I trust it. visiting from www.rrsport.co.uk |
will308f Member Since: 19 Apr 2022 Location: plymouth Posts: 456 ![]() ![]() ![]() |
ive used a ring compressor for years ..lots better than supermarket ones i think |
Kot Member Since: 10 Mar 2021 Location: broadland Posts: 1254 ![]() ![]() |
I use a ring compressor run off the 12v supply the gauge is within a few psi accuracy but rely on the TPMS for accurate readings 2018 SE SDV8 4.4 Byron Blue |
DrRob Member Since: 16 Apr 2015 Location: Petersfield, Hampshire Posts: 4313 ![]() ![]() ![]() |
Toolstation sell a nice digital pressure gauge which I use to check after using a 240V Michelin compressor Gone to a good home: 2011 4.4 TDV8 Vogue SE Buckingham Blue with Ivory and clear glass = "Rory"
