Home > Technical (L322) > Pics of faults and live values....where is the issue?
philip1972
France 2006 Range Rover Autobiography 4.2 SC V8 Java Black
Just driving along and got the Suspension fault, max speed 30 and it dropped to low level.
These are the 2 faults, along with live values of calibration, and height sensor stuff.
I have no idea what the value should be.
Please help me Bow down
Post #627596 2nd Apr 2022 12:32pm
philip1972
Not sure if useful or not, but the car does not drop at all, even after 2 weeks, so I dont think there is a leak.
Post #627601 2nd Apr 2022 3:56pm
scotcruz
Scotland 2010 Range Rover HSE TDV8 Zambezi Silver
Got your message..
Mine wasn't a leak either.. a lot of the problems started when my battery was on the way out.. the classic symptom is the amp crackling when the battery starts to drop.
I only experienced it once after I had replaced the front control arms. The suspense level sensor must have not liked it.. I changed the battery (yours night be fine) and then calibrated the height sensors using IId Tool. (It walks you through the procedure)
Hope this helps. Current:
- L560 Velar HSE R-Dynamic D180
- Peugeot 508 2011 - 2.2 HDi GT
Past:
- FFRR V 2010 - 3.6 TDV8
- Citroen C4 1.6i Petrol
- Mitsubishi Shogun 3.2 DID
- Peugeot 607 2.2 HDi
- Nissan Primera 1.8 SVE
- Honda Civic 1.6 VTEC
Post #627685 4th Apr 2022 2:47am
philip1972
Thank you.
Battery is good (only a month old), and the issue was happening before that as well as on Saturday.
It seems very intermittent, it happened last time about 3 months ago!
Post #627686 4th Apr 2022 6:55am
Robert
France 2007 Range Rover Vogue 4.4 V8 Zambezi Silver
live values look normal, I think 1,3 is the minimum. All the U codes are electronic miscommunication codes. As far as I know a good suspension calibration with the IID tool will help you out. If not, a sensor might ask for a look in the carconfig check.
Bear in mind I'm a non tech and have spend hours with that sacred IID tool.
If not, have you tried a battery reset?
Post #627698 4th Apr 2022 10:49am
philip1972
Thanks. I did a thorough calibration 2 moths ago, but I guess there is no harm in doing another.
Post #627699 4th Apr 2022 10:52am
maric995
Croatia 2006 Range Rover HSE 4.4 V8 Zambezi Silver
try driving with off road screen on, you can then see all four wheel heights live on the screen. I had problematic height sensor which had correct voltage and height when stationary, but it would go crazy with values when driving, I tracked it with off road screen and replaced with new height sensor and now is all good Wink RR HSE 4.4 2006 LPG
Post #627782 5th Apr 2022 8:37am
philip1972
Thank you.
I had to tow a large trailer and off road buggy today, 50km each way and there were no issues at all Thumbs Up
I had the off road screen on and nothing unusual was happening, and also had the live values on the IID. Again, nothing untoward?
Something is amiss, as it has done it 3 or 4 times over the last 4 months.
Just cant find out what Censored
Post #627808 5th Apr 2022 4:20pm
RR2B
United Kingdom 2011 Range Rover Autobiography 4.4 V8 Baltic Blue
Exact same issue and same solution, turned out to be a dodgy height sensor - even though height sensor fault didn't come up on the IID. 2011MY 4.4TDV8 Autobiography Baltic Blue
TVR Griffith
Alfa Romeo Mito QV
Post #627824 5th Apr 2022 6:17pm
RRYorks
United Kingdom 2010 Range Rover Vogue TDV8 Barolo Black
I had the same problem with a brand new height sensor, tried everything, traced all the wiring and tested every connection. When you looked at the live value, it fluctuated VERY SLIGHTLY, sensor returned to dealer who replaced without argument, problem fixed 2010 3.6 TDV8
Post #628026 7th Apr 2022 12:52pm
