![]() | Home > Technical (L322) > Pics of faults and live values....where is the issue? |
philip1972 Member Since: 16 Jun 2017 Location: Marval 87440 Posts: 526 ![]() ![]() ![]() |
Not sure if useful or not, but the car does not drop at all, even after 2 weeks, so I dont think there is a leak. |
scotcruz Member Since: 03 May 2017 Location: S C O T L A N D Posts: 391 ![]() ![]() ![]() |
Got your message..
Thank you.
Robert Member Since: 25 Oct 2011 Location: Perigueux Posts: 2289 ![]() ![]() ![]() |
live values look normal, I think 1,3 is the minimum. All the U codes are electronic miscommunication codes. As far as I know a good suspension calibration with the IID tool will help you out. If not, a sensor might ask for a look in the carconfig check.
Thanks. I did a thorough calibration 2 moths ago, but I guess there is no harm in doing another. |
maric995 Member Since: 04 Apr 2019 Location: zagreb Posts: 58 ![]() ![]() ![]() |
try driving with off road screen on, you can then see all four wheel heights live on the screen. I had problematic height sensor which had correct voltage and height when stationary, but it would go crazy with values when driving, I tracked it with off road screen and replaced with new height sensor and now is all good |
Thank you.
RR2B Member Since: 04 Aug 2020 Location: Rowlands Castle Posts: 254 ![]() ![]() ![]() |
Exact same issue and same solution, turned out to be a dodgy height sensor - even though height sensor fault didn't come up on the IID. 2011MY 4.4TDV8 Autobiography Baltic Blue TVR Griffith Alfa Romeo Mito QV |
RRYorks Member Since: 13 Jan 2020 Location: Yorkshire Posts: 41 ![]() ![]() ![]() |
I had the same problem with a brand new height sensor, tried everything, traced all the wiring and tested every connection. When you looked at the live value, it fluctuated VERY SLIGHTLY, sensor returned to dealer who replaced without argument, problem fixed 2010 3.6 TDV8 |
