Home > In Car Electronics (L322) > Bluetooth Module Failure?
harleyman
Spain
With those battery readings battery IS nota in good condición
Bluetooth module Censored on with the igniton and if battery IS low it Will not power on and you Will have issuea with the radio.
You can conect junpping wires to other car battery and sitch on the igniton and If would bet that bluetooth Will show 2012 Range Rover 4.4 tdv8 Autobiography
Post #628830 16th Apr 2022 11:32pm
Mike Edwards
United Kingdom 2013 Range Rover Vogue SE SDV8 Causeway Grey
Curious situation with the Bluetooth module. I bought a MOST bypass connector and unplugged the Bluetooth module and the radio started behaving itself once again. I pulled the module apart and found absolutely nothing obviously wrong so I put it back together and plugged it all back in. Clearly the radio didn't work but when I unplugged it again and fitted the bypass module the radio refused to play. No idea what happened or why. All rather confusing.
Post #633496 1st Jun 2022 10:48pm
mpirie
Sounds like disconnecting both the MOST fibre and copper cable then fitting the MOST bypass is telling the head unit not to bother looking for a BT unit as it's not there. That allows the radio to work.
If you then reconnect the copper connector then the head unit will be looking for the BT unit and finding a faulty one, stopping the radio from working.
The failure in the BT unit may not be obvious and the only way to be sure is to swap it out with a known good unit.
Mike
Post #633512 2nd Jun 2022 8:35am
Mike Edwards
That doesn’t explain why the bypass worked fine at the first attempt and then failed to work on subsequent attempts.
Post #633520 2nd Jun 2022 9:33am
Mike Edwards
With the bluetooth ,module bypassed the only permanent error I'm getting is that the Parking parking sensor control module is missing. After a bit of driving it usually adds the parking brake control module to that list which is rather bizarre as the parking brake continues to work. The latest error is that the DAB unit has a system internal failure.
Anyone know where the DAB unit sits? Is there a common element to all of these? Could it be the antenna module? Is there something I can do to test whether this is functioning properly?
Post #635304 23rd Jun 2022 9:10pm
Not the username I wanted
Australia 2010 Range Rover Vogue 5.0 V8 Alaska White
G'day Mike,
I've just got a very similar issue with my MY10 L322, but it was pretty easy to determine that mine was caused by water ingress after a pretty severe storm the other night.
I had the exact same symptoms as you initially, but now I have the screen-saver of death and no parking sensors. I'd had trouble with the parking sensors previously, and had taken the bumper off and cleaned and checked them, and they were working again, but on reflection, it may have been the start of the water problem, which is obvious now. It could be that you have a water problem, but not obvious.
After work today I'm going to remove the modules and try to dry them out and resuscitate things.
Did you get to the bottom of your issue?
Regards,
Eddy
Post #657939 27th Feb 2023 1:25am
Mike Edwards
Interesting. Thanks.
I've been struggling to work out where the parking sensor control module is located.
Any and all suggestions would be welcome.
Post #657974 27th Feb 2023 3:24pm
oggy
United Kingdom 2007 Range Rover Vogue SE 4.2 SC V8 Java Black
bigbo wrote:
Hi the parking aid module is in the right hand cubby, the BT module is in the left cubby with all the audio kit. So probably not related.
The BT module is on the top of the stack of audio equipment. To check if its the BT module causing your issues you need to remove it from the MOST ring and connect a MOST bypass connector (available on eBay) so that the MOST ring is complete. If this clears your problem then you have proved that the BT module is faulty.
Mine is a MY06 which had a Nokia module but I swapped it for a 2010 module, hopfully this picture will help a little, the BT module is the one at the top with the orange MOST cable
David
hi bigbo have you done any link-up on the rse module I see you have 3 cables coming out of your top connector oggy new vehicle purchase
2007 supercharged 4.2 java black .sand leather vogue se trim
previous cars .
range rover classic 200 tdi
discovery 1 200 tdi
freelander 2 2008 hse
discovery 1 300 tdi
p38 4.0 ltr man r380 ex royal support vehicle on v5c
discovery td5 man off roader
Post #657982 27th Feb 2023 4:41pm
bigbo
United Kingdom 2006 Range Rover Supercharged 4.2 SC V8 Buckingham Blue
There is only two optical cables connected to the RSE module, the third that is visible is running behind to the TV tuner.
Just an optical illusion! Rolling with laughter
David Range Rover 4.2 Supercharged 2006
Ford Focus EcoBoost 1.5 2017
MG TF 2003
Previous Cars of note
Land Rover Discovery 2
Jaguar Mk2 3.8 - Company car
MG Midget 1974 - Concours
Post #657985 27th Feb 2023 4:57pm
oggy
optical illusion very good i can see it now Thumbs Up new vehicle purchase
previous cars .
discovery 1 200 tdi
discovery 1 300 tdi
Post #657986 27th Feb 2023 5:07pm
BigEnglishWagon
New Zealand 2005 Range Rover Vogue 4.4 V8 Adriatic Blue
Hello bigbo,
I have replaced the original Nokia unit for the AH42-10F845-AA module.
I have a pairing 2121 issue. I see on this forum many have pairing issues.
I find if I have my iPhone at the Bluetooth menu, click on the Land Rover name it may result in pairing. There appears to be a small window after getting into the LR, inserting the IGN key, turning to the second position, sometimes results in pairing.
I realise your LR is a year newer but we have both inserted a new BT module.
This making the iPhone pair is automatic in other non LR vehicles I have paired with previously.
Do you have or had a similar puzzle.
Post #697402 4th Aug 2024 11:55am
bigbo
Sorry cant help as I do not have an iphone. My phone connected day 1 and has never failed. Range Rover 4.2 Supercharged 2006
MG TF 2003
Post #697411 4th Aug 2024 3:47pm
BigEnglishWagon
Thank you for your reply.
I have tried an Android Phone with the same problem.
On power on the LR screen lights up, sometimes with the message No phone Found.
There is a sound from the rear speakers like a single quiet Bong. If I try to connect/pair before the Bong, 8 out of 10 we connect.
The new Bluetooth module I have was from a working vehicle.
Thank you again.
Post #697421 5th Aug 2024 5:18am
