![]() | Home > Technical (L322) > L322 Rear Subframe Removal & Rust Treatment |
Sandyt Member Since: 07 Nov 2013 Location: Wraysbury Windsor Posts: 2279 ![]() ![]() ![]() |
Hi David I have at some time or another replaced all the bushes on the rear as well as the shocks and the brake pipes - it seems logical to replace them when the subframe was partially dropped - its more fiddly than anything and dont forget the electrics to everything. Cant remember there being anything terrible other than the usual seized bolts.
dhallworth Member Since: 10 Oct 2011 Location: Glasgow Posts: 3203 ![]() ![]() ![]() |
Thanks Sandy, I agree, seems a waste of time to go this far and not do everything in one go. Especially now there's not a bush or ball joint on the front that hasn't been changed.
What's everyones thoughts on rust treatment for the rear subframe?
Bean19844 Member Since: 25 Oct 2020 Location: Essex Posts: 929 ![]() ![]() ![]() |
Seen as you've got the time, space and skill set to remove the subframe I think I'd go and hand it in to a shot blasting place, get them to go through it so you'll find any rust patches. Least that way you'll know where you stand with the frame I guess
Baltic Blue Member Since: 13 Aug 2015 Location: North Wales Posts: 3823 ![]() ![]() ![]() |
Once you have got it back to bare metal, I would paint it with Galverfroid. It’s brilliant stuff.
That's a good thought, Mike.
reb78 Member Since: 06 Sep 2015 Location: Herts Posts: 55 ![]() ![]() |
Am watching this with interest David - I am considering the same thing currently.
I decided to with genuine Land Rover bushes to be honest. I’ve spent a fortune but at least it’s done properly.
Excellent. I will have a read. Was dropping the frame relatively painless? |
Not too bad.
Brilliant. Thanks.
I think I've decided I'm going to have this shot blasted and galvanised this week.
Rangie4fun Member Since: 26 Mar 2014 Location: Home sweet home Posts: 167 ![]() ![]() ![]() |
Hi David,
