Home > Technical (L322) > Brake pad warning |
Pawl Member Since: 07 Nov 2017 Location: West Midlands Posts: 693 |
Does the warning light manage low brake fluid too ? Paul,
6th Mar 2022 10:52pm |
knares Member Since: 22 Jun 2017 Location: Perth WA Posts: 739 |
I just got a warning saying the pads are low, I checked them recently, they looked ok RR 2005 4.4 petrol
7th Mar 2022 5:21am |
diesel Dave Member Since: 14 Aug 2015 Location: Stockport Posts: 455 |
I take it you have cleared the codes with a diags box once hot wired? I’m pretty sure even on the older ones once the code has been recorded you have to reset the ECU to make the warning light go out. |
7th Mar 2022 8:07am |
Landmark Member Since: 22 Nov 2020 Location: Hampshire Posts: 118 |
OK so have removed both sensors and looped over. Cleared fault with gap iid tool and reset by removing fuse. But fault still there. I guess the next stage is to remove cluster from dash and use multi meter back to sensor harness. But before I do I was hoping one of you lot might have wire diagramshowing dash cluster pin ident. I have 2007 to 2012 manual but not 2006. |
7th Mar 2022 8:56pm |
