Home > Technical (L322) > Brake pad warning
Landmark
United Kingdom 2010 Range Rover Vogue TDV8 Stornoway Grey
Brake pad warning
Hi all trying to trace an annoying brake pad lowvwarning on dash. L322 2006 6a chasis with td6 engine. Have dissconnected both front and back new sensors and hot wired and fault still occurs. I'm guessing must be a problem with loom can anyone fwd me wire diagram and or shed any light on where the fault may lie.
Post #625552 6th Mar 2022 8:02pm
Pawl
England 2007 Range Rover Vogue TDV8 Cairns Blue
Does the warning light manage low brake fluid too ? Paul,
2001 Discovery 2 TD5, 211,000 miles & climbing
2006 FFRR TDV8 Vogue 145,000 miles & climbing
Member of Midland (Land) Rover Owners Club, www.mroc.co.uk
Post #625574 6th Mar 2022 10:52pm
knares
Australia 2005 Range Rover Vogue 4.4 V8 Zambezi Silver
I just got a warning saying the pads are low, I checked them recently, they looked ok RR 2005 4.4 petrol
Any spelling mistakes are the fault of spellchecker
Previous MG J2, CITROEN light 15 x 2 gone unfortunately
Present MERC 180e, RANGE ROVER L322, JAGUAR XJS, MERC 280SE, MG F, JAGUAR S-Type 6v 2003, jaguar s-type 8v 2004, Ford Cougar
Post #625576 7th Mar 2022 5:21am
diesel Dave
England 2019 Range Rover Autobiography SDV8 Santorini Black
I take it you have cleared the codes with a diags box once hot wired? I’m pretty sure even on the older ones once the code has been recorded you have to reset the ECU to make the warning light go out.
Post #625584 7th Mar 2022 8:07am
Landmark
Loom for pad wear
OK so have removed both sensors and looped over. Cleared fault with gap iid tool and reset by removing fuse. But fault still there. I guess the next stage is to remove cluster from dash and use multi meter back to sensor harness. But before I do I was hoping one of you lot might have wire diagramshowing dash cluster pin ident. I have 2007 to 2012 manual but not 2006.
Post #625654 7th Mar 2022 8:56pm
