![]() | Home > Maintenance & Mods (L405) > L405 jacking pad solution - home made |
Kot Member Since: 10 Mar 2021 Location: broadland Posts: 1318 ![]() ![]() |
If you are going to use wood, use hard wood, sorry but I personally would not be trusting that |
If the type of wood can bear a heavy roof structure, it should be ok bearing one corner of a RR as a cushioning/ gripping pad.
mlambton Member Since: 30 Sep 2021 Location: Devon Posts: 68 ![]() ![]() ![]() |
Or you could buy one of these for £4.46
Not on a Saturday night or Sunday morning you can’t ![]() |
I have always used a piece of timber as a cushion between a jack and a car jacking point, usually a bit of cls timber or any lump of 100x50mm lying around. Done it for over 50 years and never had an issue. Personally l would always use a softer wood in preference to hardwood as l find soft wood gives a bit and grips rather than sliding about on hardwood.
Agree and thank you NDF |
horse86 Member Since: 09 Dec 2014 Location: PA Posts: 863 ![]() ![]() ![]() |
putting used hockey pucks to work I see 2014 FF Autobiography 5.0 SC 2008 FFRR (sold) 2008 BMW M5 |
