Home > Maintenance & Mods (L405) > L405 jacking pad solution - home made
pld118
Home made wooden (female) L405 jacking pad created today from a roof truss off-cut. Works perfectly on a Sealey 3040AG trolley jack fitted with a round rubber jacking pad.. Just the right size, correct strength, wood doesn’t split under load and the wooden block doesn’t slip whilst sitting on the rubber jacking pad when the car is being raised or lowered. Thought this worth sharing because despite doing lots of research, never quite known what type pad to order online for the L405. Hope it’s of some use to someone 👍🏻
Measured the shape/ space around the L405 jacking point and also measured the (male) jacking point that’s underneath the car. Then drew out the measured sizes on to the wood off-cut. Then used Stanley knife, saw and hammer/ wood chisel to create a suitably sized/ shaped wooden jacking pad. Then wrapped the home made wooden pad in Duct tape to stop it slipping on the round trolley jack; and to stop anyone throwing it out if they stumble across it - ie without the ‘special tape’
they could just think it’s a useless old piece of wood 😂
Pad dimensions as pictured are (approx.):
9.5 cm long - image 2
6 cm wide - image 3
4.5 depth/ height - image 4
Female jacking point recess - 9.5 cm long x 1.5 cm depth/ height - image 5
Image 1:
Image 2
Image 3
Image 4
Image 5
Post #625449 5th Mar 2022 7:27pm
Kot
If you are going to use wood, use hard wood, sorry but I personally would not be trusting that Rolling with laughter Rolling with laughter 2018 SE SDV8 4.4 Byron Blue
Post #625492 6th Mar 2022 10:00am
pld118
If the type of wood can bear a heavy roof structure, it should be ok bearing one corner of a RR as a cushioning/ gripping pad.
Thanks for the concern… main thing is, you don’t need to try it 👍🏻
Ps… resorted to home making this type pad after reading reviews about so called professionally manufactured rubber ones that had split under 4x4 load.
Post #625515 6th Mar 2022 2:10pm
mlambton
United Kingdom 2015 Range Rover Autobiography SDV8 Corris Grey
Or you could buy one of these for £4.46
https://www.ebay.co.uk/itm/282778726787 2015 Range Rover L405 SDV8 AB Corris grey
2010 Range Rover TDV6 HSE Narra Bronze sold
2006 Discovery 3 SE green sold
Defender 90 td5 sold
Defender 90 soft top sold
Post #625609 7th Mar 2022 2:57pm
pld118
mlambton wrote:
Or you could buy one of these for £4.46…
Not on a Saturday night or Sunday morning you can’t Wink
Post #625629 7th Mar 2022 5:54pm
I have always used a piece of timber as a cushion between a jack and a car jacking point, usually a bit of cls timber or any lump of 100x50mm lying around. Done it for over 50 years and never had an issue. Personally l would always use a softer wood in preference to hardwood as l find soft wood gives a bit and grips rather than sliding about on hardwood.
Suffice to say l also always use axle stands as well…….with a lump of wood between it and the car. Very Happy
Post #625630 7th Mar 2022 6:06pm
pld118
Agree and thank you NDF Bow down Thumbs Up
Ps… the effort as per the OP is brilliant. Works a treat Thumbs Up Thumbs Up
Post #625637 7th Mar 2022 7:06pm
horse86
United States 2014 Range Rover Autobiography 5.0 SC V8 Causeway Grey
putting used hockey pucks to work I see 2014 FF Autobiography 5.0 SC
2008 FFRR (sold)
2008 BMW M5
Post #626324 16th Mar 2022 5:30pm
