Home > Maintenance & Mods (L405) > L405 jacking pad solution - home made |
Kot Member Since: 10 Mar 2021 Location: broadland Posts: 1194 |
If you are going to use wood, use hard wood, sorry but I personally would not be trusting that 2018 SE SDV8 4.4 Byron Blue |
6th Mar 2022 10:00am |
If the type of wood can bear a heavy roof structure, it should be ok bearing one corner of a RR as a cushioning/ gripping pad.
6th Mar 2022 2:10pm |
mlambton Member Since: 30 Sep 2021 Location: Devon Posts: 67 |
Or you could buy one of these for £4.46
7th Mar 2022 2:57pm |
Not on a Saturday night or Sunday morning you can’t |
7th Mar 2022 5:54pm |
nicedayforit Member Since: 11 Jun 2011 Location: Beside the Solway Posts: 3971 |
I have always used a piece of timber as a cushion between a jack and a car jacking point, usually a bit of cls timber or any lump of 100x50mm lying around. Done it for over 50 years and never had an issue. Personally l would always use a softer wood in preference to hardwood as l find soft wood gives a bit and grips rather than sliding about on hardwood.
7th Mar 2022 6:06pm |
Agree and thank you NDF
7th Mar 2022 7:06pm |
horse86 Member Since: 09 Dec 2014 Location: PA Posts: 860 |
putting used hockey pucks to work I see 2014 FF Autobiography 5.0 SC 2008 FFRR (sold) 2008 BMW M5 |
16th Mar 2022 5:30pm |
