Home > Maintenance & Mods (L322) > Refuelling Frustrations
paulwlincs
Hi fellow enthusiasts , i am experiencing increasing difficulty refuelling my car , it's always been difficult with the pump clicking off at the slightest squeeze of the lever , i normally get round it by positioning the pump nozzle at the 9 o clock angle but even this is not working , i can be 5 minutes putting £20 worth in which isn't ideal .
There dosen't seem to be any restrictions in the filler neck and the yellow incorrect fuel flap is not deployed , is there another vent somewhere that might be blocked ? . 2011 tdv8 4.4 vogue Santorini black
Post #624303 21st Feb 2022 9:29am
JMC
Try turning the nozzle completely upside down so that you are pulling the filler lever down towards the ground! The older I get, the more I realise that people confuse wrinkles for wisdom Smile
Post #624307 21st Feb 2022 10:37am
Mr Tee
It’s a quirk of the filler neck . Upside down works great Thumbs Up
Post #624308 21st Feb 2022 10:39am
paulwlincs
i tried that this morning but it didn't make any difference ,Thank You for the advice though . 2011 tdv8 4.4 vogue Santorini black
Post #624320 21st Feb 2022 11:55am
TDV8 Paul
Weird that didn’t work for you, I found this same thing and the upside down trick works well, although people think I’m mental when they see me do it 😂 2009 (2010 MY) 5.0 Supercharged Autobiography
2007 TDV8 Vogue SE
2005 BMW E63 645ci
2024 Porsche Macan
Post #624342 21st Feb 2022 5:38pm
Rambles
Maybe the misfuelling protector has deployed….you just can’t see it
I would use the yellow reset tool
Just to be sure
Post #624385 21st Feb 2022 11:14pm
Tinman
United Kingdom 2017 Range Rover Autobiography SDV8 Silicon Silver
My refuelling yellow had been deployed before I bought it and was damaged in the filler? I got a heavy gauge wire and pulled it out, it`s only for the wrong fuel nozzle being put in, had no troble after the removal.
Post #624389 22nd Feb 2022 12:54am
tj196443
United Kingdom 2010 Range Rover Vogue TDV8 Zermatt Silver
I had the same problem with my 3.6 when I first got it, when I did the wiring repair in the fuel tank I had to open the inspection panels to the tank under the rear seats. Since I’ve done that I haven’t had any problems refuelling, I just guessed it was air in the tanks that was slowing down refuelling.
Post #624400 22nd Feb 2022 10:51am
V8 Bob
Filled up this afternoon ( mortgage acceptance received ) the fuel pump cut off at first but with it angled at 45degrees to the rear of the car it worked ok and I could gradually increase the flow without it cutting out.
When I fist got the car the garage went to put some fuel in and triggered the misfuelling device so when I tried to top it up would only accept a drizzle until I had reset it. 2012 tdv8 Westminster arrived Jan 19 gone Dec 23
RR classic v8 bobtail gone
300 tdi Discovery 3 dr gone
Post #624420 22nd Feb 2022 4:38pm
dhallworth
There was a TSB for problems filling the TDV8 with diesel years ago. Our first TDV8 had it done and it cured the problems filling it.
I’m sure the solution was a new filler pipe but it was years ago it was done.
Post #624441 22nd Feb 2022 8:04pm
