Home > Maintenance & Mods (L322) > Refuelling Frustrations
paulwlincs
Hi fellow enthusiasts , i am experiencing increasing difficulty refuelling my car , it's always been difficult with the pump clicking off at the slightest squeeze of the lever , i normally get round it by positioning the pump nozzle at the 9 o clock angle but even this is not working , i can be 5 minutes putting £20 worth in which isn't ideal .
There dosen't seem to be any restrictions in the filler neck and the yellow incorrect fuel flap is not deployed , is there another vent somewhere that might be blocked ? . 2011 tdv8 4.4 vogue Santorini black
Post #624303 21st Feb 2022 8:29am
JMC
Scotland 2012 Range Rover Westminster TDV8 Orkney Grey
Try turning the nozzle completely upside down so that you are pulling the filler lever down towards the ground! The older I get, the more I realise that people confuse wrinkles for wisdom Smile
Post #624307 21st Feb 2022 9:37am
Mr Tee
It’s a quirk of the filler neck . Upside down works great Thumbs Up
Post #624308 21st Feb 2022 9:39am
paulwlincs
i tried that this morning but it didn't make any difference ,Thank You for the advice though . 2011 tdv8 4.4 vogue Santorini black
Post #624320 21st Feb 2022 10:55am
TDV8 Paul
Weird that didn’t work for you, I found this same thing and the upside down trick works well, although people think I’m mental when they see me do it 😂 2009 (2010 MY) 5.0 Supercharged Autobiography
2007 TDV8 Vogue SE
2005 BMW E63 645ci
2024 Porsche Macan
Post #624342 21st Feb 2022 4:38pm
Rambles
2011 Range Rover Vogue SE TDV8 Stornoway Grey
Maybe the misfuelling protector has deployed….you just can’t see it
I would use the yellow reset tool
Just to be sure
Post #624385 21st Feb 2022 10:14pm
Tinman
United Kingdom 2017 Range Rover Autobiography SDV8 Silicon Silver
My refuelling yellow had been deployed before I bought it and was damaged in the filler? I got a heavy gauge wire and pulled it out, it`s only for the wrong fuel nozzle being put in, had no troble after the removal.
Post #624389 21st Feb 2022 11:54pm
tj196443
United Kingdom 2010 Range Rover Vogue TDV8 Zermatt Silver
I had the same problem with my 3.6 when I first got it, when I did the wiring repair in the fuel tank I had to open the inspection panels to the tank under the rear seats. Since I’ve done that I haven’t had any problems refuelling, I just guessed it was air in the tanks that was slowing down refuelling.
Post #624400 22nd Feb 2022 9:51am
V8 Bob
United Kingdom 2012 Range Rover Westminster TDV8 Ipanema Sand
Filled up this afternoon ( mortgage acceptance received ) the fuel pump cut off at first but with it angled at 45degrees to the rear of the car it worked ok and I could gradually increase the flow without it cutting out.
When I fist got the car the garage went to put some fuel in and triggered the misfuelling device so when I tried to top it up would only accept a drizzle until I had reset it. 2012 tdv8 Westminster arrived Jan 19 gone Dec 23
200 TDi discovery bobtail gone
RR classic v8 bobtail gone
300 tdi Discovery 3 dr gone
Post #624420 22nd Feb 2022 3:38pm
dhallworth
There was a TSB for problems filling the TDV8 with diesel years ago. Our first TDV8 had it done and it cured the problems filling it.
I’m sure the solution was a new filler pipe but it was years ago it was done.
2007 Range Rover Supercharged in Java Black with Ivory Leather
Post #624441 22nd Feb 2022 7:04pm
