Home > Maintenance & Mods (L322) > Refuelling Frustrations |
JMC Member Since: 01 Feb 2009 Location: Aberdeen-Angus Posts: 755 |
Try turning the nozzle completely upside down so that you are pulling the filler lever down towards the ground! The older I get, the more I realise that people confuse wrinkles for wisdom |
21st Feb 2022 9:37am |
Mr Tee Member Since: 13 Dec 2010 Location: Near Wackyjim Posts: 2643 |
It’s a quirk of the filler neck . Upside down works great |
21st Feb 2022 9:39am |
paulwlincs Member Since: 07 Oct 2019 Location: Lincoln Posts: 44 |
i tried that this morning but it didn't make any difference ,Thank You for the advice though . 2011 tdv8 4.4 vogue Santorini black |
21st Feb 2022 10:55am |
TDV8 Paul Member Since: 30 Nov 2020 Location: Tadworth Posts: 223 |
Weird that didn’t work for you, I found this same thing and the upside down trick works well, although people think I’m mental when they see me do it 😂 2009 (2010 MY) 5.0 Supercharged Autobiography
21st Feb 2022 4:38pm |
Rambles Member Since: 16 Apr 2011 Location: UK Posts: 800 |
Maybe the misfuelling protector has deployed….you just can’t see it
21st Feb 2022 10:14pm |
Tinman Member Since: 22 Mar 2017 Location: kent Posts: 1188 |
My refuelling yellow had been deployed before I bought it and was damaged in the filler? I got a heavy gauge wire and pulled it out, it`s only for the wrong fuel nozzle being put in, had no troble after the removal. |
21st Feb 2022 11:54pm |
tj196443 Member Since: 08 Oct 2018 Location: Newcastle Posts: 168 |
I had the same problem with my 3.6 when I first got it, when I did the wiring repair in the fuel tank I had to open the inspection panels to the tank under the rear seats. Since I’ve done that I haven’t had any problems refuelling, I just guessed it was air in the tanks that was slowing down refuelling. |
22nd Feb 2022 9:51am |
V8 Bob Member Since: 15 Mar 2018 Location: Cumbria Posts: 357 |
Filled up this afternoon ( mortgage acceptance received ) the fuel pump cut off at first but with it angled at 45degrees to the rear of the car it worked ok and I could gradually increase the flow without it cutting out.
22nd Feb 2022 3:38pm |
dhallworth Member Since: 10 Oct 2011 Location: Glasgow Posts: 3068 |
There was a TSB for problems filling the TDV8 with diesel years ago. Our first TDV8 had it done and it cured the problems filling it.
22nd Feb 2022 7:04pm |
