Home > Technical (L405) > Topix tech bulletin SSM63877
FF777
Hi
Can someone help me find technical bulletin SSM63877 on topic please?
Thanks
Post #623490 12th Feb 2022 10:54pm
this?
SSM63877 - L405 V8 Transmission Heat Shield Vibration 1400-1600 rpm ... - .- -.
Post #623536 13th Feb 2022 10:23am
FF777
Hi yes thanks
I need the actual pdf on topix with the procedure, if anyone has access to topix?
Post #623538 13th Feb 2022 10:27am
Mikey
You can buy hourly access to Topix Thumbs Up
Post #623551 13th Feb 2022 12:08pm
FF777
At 45ph
Post #623553 13th Feb 2022 12:14pm
i dont think its that much. ... - .- -.
Post #623566 13th Feb 2022 12:58pm
knwatkins
I had a problem with the transmission heat shield rattle that exposed itself at exactly 1350rpm.
The heat shield didn't look distorted at all, so I removed it and stuck some self adhesive velcro (the furry part) on the underside of the steel heat shield bracket (7H264 in the image below) to isolate the metal to metal interface between the heat shield and the bracket.
The result...silence restored.
10 minute job.
Hope this helps in the absence of the bulletin.
 Kev
2014 L405 RR Vogue SE 4.4 SDV8 in Corris Grey
2010 L320 RRS HSE 3.0 TDV6 in Stornoway Grey
Post #623596 13th Feb 2022 6:05pm
mlambton
United Kingdom 2015 Range Rover Autobiography SDV8 Corris Grey
I think I have the same issue that I can hear at tickover revs so will give that a try when im changing my fluids Thumbs Up 2015 Range Rover L405 SDV8 AB Corris grey
2010 Range Rover TDV6 HSE Narra Bronze sold
2006 Discovery 3 SE green sold
Defender 90 td5 sold
Defender 90 soft top sold
Post #623601 13th Feb 2022 6:44pm
FF777
Unnecessary quote removed
Thank you Kev much appreciated I'll give this a go, this is the issue I'm probably trying to resolve, hum/resonance on throttle loudest at 1300 rpm, the dissappears at below 1k and over 1.6k revs.
I will post an update, I have seen this issue mentioned on a few other posts with no resolution with people not reporting back
Thanks again
Post #623638 13th Feb 2022 10:48pm
FF777
Quick update
Unfortunately this didn't resolve my issue, the diagram is for a petrol v8 I believe. My sdv8 doesn't have the same gearbox brackets
Anyway I will keep hunting around for the source, I will post back if I have any updates
Post #624340 21st Feb 2022 4:35pm
knwatkins
Mines an SDV8 and it's what I did.
What's under the gearbox heat shield on yours? Have you got an pictures? Kev
Post #624353 21st Feb 2022 6:42pm
FF777
My undertray looks exactly like this, I turned the engine on without the heatshield but the vibration is still audible, I will link to a post with an audio clip
Post #624438 22nd Feb 2022 6:52pm
FF777
https://www.fullfatrr.com/forum/topic55105.html
Post #624440 22nd Feb 2022 7:01pm
knwatkins
Ah that's a shame. They must have changed it between 2014 and 2016. Kev
Post #624444 22nd Feb 2022 7:27pm
