![]() | Home > Maintenance & Mods (L322) > L322 4.4 2011 adaptive suspension air leak |
SFM Member Since: 19 Feb 2012 Location: dordogne Posts: 258 ![]() ![]() ![]() |
Just had mine done last week, apparently it’s quite a common problem, cost me 1400€!
stuartj9 Member Since: 18 Apr 2019 Location: Liverpool Posts: 86 ![]() ![]() ![]() |
Oh dear. Can they be reconditioned? Does anyone know the part number? |
Range Rover L322 Member Since: 03 Sep 2019 Location: South West Posts: 335 ![]() ![]() |
Sounds like a Mcpherson strut.
Cheers but is this part for the 2011 with the adaptive dynamic suspension? From what I've read and spoken to an indy, this model is the more expensive part. I just don't want to get the wrong one. |
kevinp Member Since: 28 Sep 2019 Location: Telford Posts: 1307 ![]() ![]() ![]() |
Hi Stuart. Do a search for just the air bag. They are about £300ish.
mjdronfield Member Since: 04 Nov 2011 Location: Derbyshire Posts: 7916 ![]() ![]() ![]() |
The air system is the springs, the adaptive bit is the shockers/dampers. So the air spring can be changed separately, but like normal best practice it tends to get replaced in pairs, but that’s obviously up to you.
diesel Dave Member Since: 14 Aug 2015 Location: Stockport Posts: 475 ![]() ![]() ![]() |
Hi Stuart. I’ve done quite a few of these, you’ll probably find you had the leak first which caused the compressor to overwork then give up.
paulbrown22 Member Since: 23 Dec 2017 Location: London/Poole Posts: 358 ![]() ![]() ![]() |
Seems to be about the right age for this to happen if they are the original struts, judging from my own experience and other feedback on here. My 2011 5.0 S/C developed a slow leak in the front right strut just before COVID, a couple of days after I'd been using it in offroad/extended height, which clearly caused the bag to flex in a place where the rubber was longer very flexible!
DrRob Member Since: 16 Apr 2015 Location: Petersfield, Hampshire Posts: 4334 ![]() ![]() ![]() |
Had the same. Changed just the air bag with a kit from Advanced Factors. Strut was not replaced. Gone to a good home: 2011 4.4 TDV8 Vogue SE Buckingham Blue with Ivory and clear glass = "Rory"
Cheers. Is this the correct one for a 2011?
Looks it. Would need to check my invoice... Gone to a good home: 2011 4.4 TDV8 Vogue SE Buckingham Blue with Ivory and clear glass = "Rory"
Or would it be easier with this? They're not far from me so I could pick up. I know it's Dunlop but I'm not planning on keeping the car. It's being traded in.
Part turned up today. Does anyone have a video on how to change the bag on the VDS one? Cheers. |
Update. Bag changed and no leak. A small issue though ;
