Home > Maintenance & Mods (L322) > L322 4.4 2011 adaptive suspension air leak |
SFM Member Since: 19 Feb 2012 Location: dordogne Posts: 258 |
Just had mine done last week, apparently it’s quite a common problem, cost me 1400€!
11th Feb 2022 11:30pm |
stuartj9 Member Since: 18 Apr 2019 Location: Liverpool Posts: 86 |
Oh dear. Can they be reconditioned? Does anyone know the part number? |
11th Feb 2022 11:39pm |
Range Rover L322 Member Since: 03 Sep 2019 Location: South West Posts: 327 |
Sounds like a Mcpherson strut.
12th Feb 2022 12:06am |
Cheers but is this part for the 2011 with the adaptive dynamic suspension? From what I've read and spoken to an indy, this model is the more expensive part. I just don't want to get the wrong one. |
12th Feb 2022 8:57am |
kevinp Member Since: 28 Sep 2019 Location: Telford Posts: 1184 |
Hi Stuart. Do a search for just the air bag. They are about £300ish.
12th Feb 2022 9:39am |
mjdronfield Member Since: 04 Nov 2011 Location: Derbyshire Posts: 7708 |
The air system is the springs, the adaptive bit is the shockers/dampers. So the air spring can be changed separately, but like normal best practice it tends to get replaced in pairs, but that’s obviously up to you.
12th Feb 2022 11:33am |
diesel Dave Member Since: 14 Aug 2015 Location: Stockport Posts: 449 |
Hi Stuart. I’ve done quite a few of these, you’ll probably find you had the leak first which caused the compressor to overwork then give up.
12th Feb 2022 2:41pm |
paulbrown22 Member Since: 23 Dec 2017 Location: London/Poole Posts: 352 |
Seems to be about the right age for this to happen if they are the original struts, judging from my own experience and other feedback on here. My 2011 5.0 S/C developed a slow leak in the front right strut just before COVID, a couple of days after I'd been using it in offroad/extended height, which clearly caused the bag to flex in a place where the rubber was longer very flexible!
13th Feb 2022 11:58pm |
DrRob Member Since: 16 Apr 2015 Location: Petersfield, Hampshire Posts: 4286 |
Had the same. Changed just the air bag with a kit from Advanced Factors. Strut was not replaced. Gone to a good home: 2011 4.4 TDV8 Vogue SE Buckingham Blue with Ivory and clear glass = "Rory"
14th Feb 2022 9:03am |
Cheers. Is this the correct one for a 2011?
15th Feb 2022 10:48pm |
Looks it. Would need to check my invoice... Gone to a good home: 2011 4.4 TDV8 Vogue SE Buckingham Blue with Ivory and clear glass = "Rory"
16th Feb 2022 8:37am |
Or would it be easier with this? They're not far from me so I could pick up. I know it's Dunlop but I'm not planning on keeping the car. It's being traded in.
16th Feb 2022 10:43am |
Part turned up today. Does anyone have a video on how to change the bag on the VDS one? Cheers. |
17th Feb 2022 12:09pm |
Update. Bag changed and no leak. A small issue though ;
19th Feb 2022 11:45pm |
