Home > Maintenance & Mods (L322) > L322 4.4 2011 adaptive suspension air leak
stuartj9
United Kingdom 2006 Range Rover Vogue TDV8 Java Black
So I've had the car back to the garage abd had the compressor changed due to a fault. This was changed and as far as I'm aware, nothing else was changed (eg reset using diagnostics) is this right?
Anyway, after having this done abd it could be a coincidence, I know have suspension fault. The compressor is over heating, won't let me go over 30mph when a warning comes on. I can hear air hissing out from the drivers side front wheel. Question is has the garage caused the issue and two, can the air suspension be replaced /fixed or does it need an entire strut? What are my options? Thanks!
Post #623365 11th Feb 2022 10:15pm
SFM
France 2012 Range Rover Vogue TDV8 Rimini Red
Just had mine done last week, apparently it’s quite a common problem, cost me 1400€!
Car has only done 60k
Best of luck mate
Post #623367 11th Feb 2022 10:30pm
stuartj9
Oh dear. Can they be reconditioned? Does anyone know the part number?
Post #623368 11th Feb 2022 10:39pm
Range Rover L322
Sounds like a Mcpherson strut.
A decent mechanic will find it with soapy water and tell you what to replace.
It's age rather than mileage, and usually hits the passenger side front first as that takes the most wear/bumps being on the side of the road. They generally go when the temperature drops , 2 years ago last Sep a load off FFRR members reported the same in one weekend!
It's not a big deal and a reasonably easy job for a LR mechanic. £322 Bearmach.
https://www.bearmach.com/product/air-sprin...VeEALw_wcB 2012 L322 4.4 TDV8 AB low mileage - a peach
1986 V8 Defender 90 County ex-Swiss Army - Red everything....
My preferred Independent: Roy Hardy. R & B AUTOS LTD, 20 Brook Road, Wimborne, Dorset, BH21 2BH 07500 866775‬ (Ex LR Chief Technician)
Post #623369 11th Feb 2022 11:06pm
stuartj9
Cheers but is this part for the 2011 with the adaptive dynamic suspension? From what I've read and spoken to an indy, this model is the more expensive part. I just don't want to get the wrong one.
Post #623377 12th Feb 2022 7:57am
kevinp
Hi Stuart. Do a search for just the air bag. They are about £300ish.
From what I've read, don't buy cheap ones.
Post #623382 12th Feb 2022 8:39am
mjdronfield
The air system is the springs, the adaptive bit is the shockers/dampers. So the air spring can be changed separately, but like normal best practice it tends to get replaced in pairs, but that’s obviously up to you.
Previous cars :
2003 Range Rover Vogue TD6
1999 Discovery Td5 ES
1995 BMW M5 3.8 6 speed
1992 BMW M5 3.8
1988 BMW 735i SE
1989 Ford Sierra XR4x4 2.9i
1981 Ford Fiesta Supersport
Post #623393 12th Feb 2022 10:33am
diesel Dave
England 2019 Range Rover Autobiography SDV8 Santorini Black
Hi Stuart. I’ve done quite a few of these, you’ll probably find you had the leak first which caused the compressor to overwork then give up.
You can just change the bag or the whole strut, always better to do both if changing the strut as the dampers do lose some performance with age.
Post #623428 12th Feb 2022 1:41pm
paulbrown22
United Kingdom 2011 Range Rover Supercharged 5.0 SC V8 Stornoway Grey
Seems to be about the right age for this to happen if they are the original struts, judging from my own experience and other feedback on here. My 2011 5.0 S/C developed a slow leak in the front right strut just before COVID, a couple of days after I'd been using it in offroad/extended height, which clearly caused the bag to flex in a place where the rubber was longer very flexible!
Personally I changed the complete pair of front struts given they were nearly 10 years old and had done something like 75k miles, that was a pretty easy job on the driveway at home if you have some reasonable jacks and sockets/bars. You can just replace the bags and save a bit of money, need to ensure the new bags are properly fitted to seal correctly though otherwise you'll have different leaks...
Post #623639 13th Feb 2022 10:58pm
DrRob
Had the same. Changed just the air bag with a kit from Advanced Factors. Strut was not replaced. Gone to a good home: 2011 4.4 TDV8 Vogue SE Buckingham Blue with Ivory and clear glass = "Rory"
Post #623647 14th Feb 2022 8:03am
stuartj9
Cheers. Is this the correct one for a 2011?
https://www.advancedfactors.co.uk/lr051700...5312-p.asp
Post #623840 15th Feb 2022 9:48pm
DrRob
Looks it. Would need to check my invoice... Gone to a good home: 2011 4.4 TDV8 Vogue SE Buckingham Blue with Ivory and clear glass = "Rory"
Post #623866 16th Feb 2022 7:37am
stuartj9
Or would it be easier with this? They're not far from me so I could pick up. I know it's Dunlop but I'm not planning on keeping the car. It's being traded in.
https://www.lrparts.net/lr032560-front-dun...mping.html
Post #623879 16th Feb 2022 9:43am
stuartj9
Part turned up today. Does anyone have a video on how to change the bag on the VDS one? Cheers.
Post #623979 17th Feb 2022 11:09am
stuartj9
Update. Bag changed and no leak. A small issue though ;
Adaptive dynamic suspension fault in the dash. I've checked the wires, they look OK. One was looking worse for wear from before this so I've tidied it up.
Anything I should be looking for?
On the plus side, replacing the bag wasn't hard.
Post #624207 19th Feb 2022 10:45pm
