Home > Maintenance & Mods (L322) > Wheel ramp recommendations
Ffrr-lover
United Kingdom 2012 Range Rover Vogue SE 4.4 V8 Santorini Black
Good morning ladies and gentlemen, boys and girls…
I am looking for some wheel ramps to make under car maintenance easier and am looking for some suggestions for what to get.
Because life is life, things are never quite straight forward… in this case I’m in need of a set that can accommodate a slight slope on one side while still keeping the car level (I’m thinking for gearbox, diff, etc where the car needs to be level). Maybe a set that has “steps” as part of the ramp so I can place each wheel 1, 2, or 3 steps up?
Or would I be better getting a set with built in jacks so I can raise those corners?
The drive drops from the back (near the house) to the front, plus the right corner (near the road) drops even further. And, to make under car work more fun, it’s a gravel driveway too! I have a small roll of carpet I move around as I need it.
Any suggestions or alternate ideas? Currently driving: 2012 L322 SE Overfinch 4.4 tdv8
Past rides:
2014 Audi Q7 3.0d (good riddance)
2010 L322 Autobiography 5.0 Supercharged
2011 L320 HSE 3.0 sdv6
2014 Jaguar XF-RS 5.0 supercharged
2007 BMW 535D
2005 Mini Cooper S
https://www.fullfatrr.com/forum/topic59478.html
Post #621924 31st Jan 2022 8:12am
cass
Move?
Post #621928 31st Jan 2022 8:28am
Goldstar
2011 Range Rover Autobiography TDV8 Stornoway Grey
Hydraulic ramps. Not sure if you can get a set that you can raise to different heights?
Post #621936 31st Jan 2022 9:33am
Baltic Blue
This set up works well for me on my sloping drive, but you would have to place the lower side ramp on blocks to overcome side to side slope.
Mike G reg 2.5VM Vogue Portofino red 1991- 1999
Post #621939 31st Jan 2022 9:59am
batfink
2004 Range Rover Vogue 4.4 V8 Adriatic Blue
Fiamma Level Up Jumbo - £39.95 for a pair - http://www.fiammastore.com/Fiamma-Leveller...-Levellers
Don't forget a pair of wheel chocks from Amazon or SGS - https://www.sgs-engineering.com/wcr04-extr...NMEALw_wcB
Post #621952 31st Jan 2022 12:13pm
there are normally a pair of chocks in the spare wheel compartment.. ... - .- -.
Post #621953 31st Jan 2022 12:16pm
Ffrr-lover
cass wrote:
Move?
Laughing
It’s on the list!
Unfortunately location, demand, poor wife life choices hindering that plan! Currently driving: 2012 L322 SE Overfinch 4.4 tdv8
Past rides:
2007 BMW 535D
2005 Mini Cooper S
Post #621960 31st Jan 2022 1:43pm
Strider
I recently sold some 5T Rhino ramps on here, they are supposed to be very good or anything of a similar design and strength capacity..
When I replaced my brake lines I reinforced the existing ramps with more angle iron uprights and used them in
conjunction with the extension pieces that I made (to get my Octavia Vrs on them). These now have a slight curve in them Smile
Post #621961 31st Jan 2022 1:44pm
Ffrr-lover
I did see a set a while back that had that. You drove onto the top part of the same and jack it up. It was an expensive option so moved on… Currently driving: 2012 L322 SE Overfinch 4.4 tdv8
Past rides:
2007 BMW 535D
2005 Mini Cooper S
Post #621962 31st Jan 2022 1:44pm
Weegie
I had a set in which each ramp had a bottle jack to raise the top plate of the ramp. I got them off Ebay. IIRC they were about £100 the pair. John
GAP iiD BT
Post #621964 31st Jan 2022 2:04pm
Ffrr-lover
That was far cheaper than what I see! I thing I’ll take a nosey at the bay… Currently driving: 2012 L322 SE Overfinch 4.4 tdv8
Past rides:
2007 BMW 535D
2005 Mini Cooper S
Post #621966 31st Jan 2022 2:26pm
Ffrr-lover
That’s what I was thinking! Not a bad price too!
Thumbs Up Currently driving: 2012 L322 SE Overfinch 4.4 tdv8
Past rides:
2007 BMW 535D
2005 Mini Cooper S
Post #621967 31st Jan 2022 2:27pm
Landphil
My drive slopes two ways, so I decided which part of the drive I wanted the car to be on to work on it and made four drive on ramps out of timber, each a different height so when on them the car is level.
My old Disco 4 up on the ramps
Post #621968 31st Jan 2022 2:28pm
Bl4ckD0g
Netherlands 2010 Range Rover Autobiography 5.0 SC V8 Santorini Black
I get scared just seeing some of this. To me there is a reason why the floor should be level, and you shouldn’t use a ramp to make it level and lift.
I’d focus on levelling the ground first.
Post #621972 31st Jan 2022 3:27pm
Landphil
From a safety point of view it’s not an issue, the car is totally stable. It’s only about an extra 5 inches off the ground and I check with the car in N, EPB off that the car doesn’t move. Then, with the car in P and EPB on and the wheels chocked ( the chock you can see is held in with a long screw) I raise the suspension, stop the engine and put axle stands under the chassis. Finally I always open a door. Nothing moves.
Today a friend is discussing with a local garage why his car fell off a four poster while they were working on it.
Post #622024 31st Jan 2022 7:22pm
