Home > General (L460 2022) > PHEV Specs
Page 1 of 3 123>
Philip
PHEV Specs
https://www.autocar.co.uk/car-news/new-car...e-ev-range
Post #621531 27th Jan 2022 2:21am
Eirik34
Norway
Great Phillip - 70 miles / 113km EV range - impressive! This looks good Very Happy
Post #621533 27th Jan 2022 7:42am
Dolphinboy
54 miles/90km real world range.
Post #621535 27th Jan 2022 8:51am
RRV8SC
United Kingdom 2015 Range Rover Autobiography 5.0 SC V8 Santorini Black
Very good for a PHEV. Imagine what the BEV version will do if this is anything to go by.
The PHEV is doing 1.8 miles per kWh. So to get to a range of 300 miles it only needs about 166kw of battery.
Post #621539 27th Jan 2022 9:40am
EdJ
Thanks for the link. The more powerful hybrid is short wheel base only. Wonder why that is? That is frustrating, as I was going to go for the LWB P510e. 2024 Range Rover P550e AB
Post #621543 27th Jan 2022 11:19am
Eirik34
Norway
It has slightly lower (~10mm) clearance as well, and only 2500kg towing capacity. But still definitely a very capable vehicle!
Got information that it could be delivered from Q3 this year. A "bit" more expensive in Norway; around £168' for a P440e AB. Still very tempting!
Post #621560 27th Jan 2022 3:33pm
jez000
United Kingdom 2011 Range Rover Vogue SE TDV8 Bournville
Does anyone know if this PHEV is permanent 4 wheel drive even when the battery is depleted ? I know models like the XC90 PHEV are two wheel drive without the battery so wondering if this is the same ? 2021 P400 Silicon Silver AB
Gone 2011 Bournville TDV8 VSE
Gone 2008 Black Canadian HSE LUX
Post #621563 27th Jan 2022 3:52pm
Philip
2500kg is very disappointing.
Post #621564 27th Jan 2022 3:53pm
Philip
Same as the non-PHEV ones, Intelligent All-Wheel Drive similar to the Defender (so can decouple the front axle for economy).
Post #621565 27th Jan 2022 3:57pm
dentaldave
United Kingdom 2018 Range Rover Autobiography SDV8 Farallon Black
Have spec’d mine today with the 510e engine.
Our caravan weighs in at 2000kg so I am happy with that
Post #621582 27th Jan 2022 6:38pm
jez000
"Same as the non-PHEV ones, Intelligent All-Wheel Drive similar to the Defender (so can decouple the front axle for economy)."
Thanks Philip, that sounds the best of both worlds if it can still have 4 wheel drive without battery and better economy with 2 wheel drive on a motorway. 2021 P400 Silicon Silver AB
Post #621588 27th Jan 2022 7:02pm
Phil.
The PHEV engines are on the builder now.
Would the likely performance and economy of the P440e be similar to the P400 when the battery was drained? Or given the battery provides c.140BHP, would the petrol engine be more likely a 300BHP version of the petrol 6 cylinder with reduced performance and possibly economy give the extra weight of the PHEV? MY23 D350 HSE
On my 7th RR plus various other JLR vehicles
Post #621591 27th Jan 2022 7:34pm
Eirik34
Norway
The P440e performance is 0-60 in 5.7 sec / 0-100km/h in 6.0 sec - not too bad!
I've also entered the queue today, P440e AB Smile
Post #621592 27th Jan 2022 7:45pm
Phil.
I assume that’s the performance with the charged battery. What will it be when the battery has discharged? MY23 D350 HSE
Post #621594 27th Jan 2022 7:50pm
7 CDB
United Kingdom 2017 Range Rover Vogue SE TDV6 Loire Blue
Nice
Going to spec ours on Sat - where did you get to on the £££ ?
Post #621602 27th Jan 2022 8:48pm
Page 1 of 3 123>
