![]() | Home > Maintenance & Mods (L405) > [Oil Dilution & DPF] An idiot's guide please |
Kot Member Since: 10 Mar 2021 Location: broadland Posts: 1311 ![]() ![]() |
Luxmoggy
luxmoggy Member Since: 19 Jun 2020 Location: Trier Posts: 494 ![]() ![]() ![]() |
I will phone the garage tomorrow for a service. I need it soon.
When you get the service, Get the dealers to test the dilution % of the oil to compare with the remote app notifications, and ask "How can this happen" how can you sell a car at x kms service interval and only achieve y kms service interval and watch them squirm
Service in 2 weeks. They said I can drive the car. For some journeys I will be using another one.
scotsjon Member Since: 02 Mar 2021 Location: highlands Posts: 44 ![]() ![]() ![]() |
Straying off topic slightly, does any know what the situation is with extended warranties if oil changes are done at home or by another garage?
To stay in LR extended warranty you need to have the services done by either a LR Dealer or a garage that is VAT registered.
will308f Member Since: 19 Apr 2022 Location: plymouth Posts: 490 ![]() ![]() ![]() |
im sure i have heard or read someone saying that they were having same sort of problem .....turns out that there throttle body/maf were all gunked up they cleaned it out and all sorted maybe worth a look ? |
TonyHammer61 Member Since: 14 Sep 2023 Location: Sidcup, Kent Posts: 11 ![]() ![]() ![]() |
Would removing the DPF solve the oil dilution problem? Would using 5W-40 C4 oil also help? At my wits end with this. I love the car (4.4 SDV8 Autobiography 2017 low mileage) but the oil/DPF issues are driving me mad. Had a new DPF fitted late last year as it was completely clogged up. Probably the previous owner set it on its way to being like that. Any help welcomed. It is either that or a take a bit hit on the value of the 4.4 and get a P400e |
Baltic Blue Member Since: 13 Aug 2015 Location: North Wales Posts: 3817 ![]() ![]() ![]() |
Tony,
This is mine that I have just measured. It takes 5 minutes. If the soot level gets up over 17.5g , take it out for a good 20 minutes minimum run 40/50mph. If the oil fuel dilution figure gets up to 4- 5, change the oil and filter (as Adrian Ajac8 says, ) get a sucker and it’s done in 20 minutes easy.,but make sure you only use C1 spec oil. I have got screenshots of mine going back 8 years and I have never had any problems. Mike. G reg 2.5VM Vogue Portofino red 1991- 1999 V reg 2.5td P38 Rioja red 1999- 2006 53 reg td6 Vogue Oslo blue 2006- 2015 11 reg 4.4 TdV8 Vogue SE. Baltic blue 2015- date. https://www.fullfatrr.com/forum/topic56162...tty+affair |
Get a Vacuum pump and do oil changes yourself in-between your yearly service, its super easy.
Thank you. I will see about the Gap Iid tool. I bought a Topdon OBR2 reader which was supposed to tell me DPF regeneration info. It tells me everything else but that. I have tried to put the Amazon link on here but it will not load. Have you got a link to a reputable site to get this Gap Iid please? Last edited by TonyHammer61 on 19th Feb 2024 3:04pm. Edited 8 times in total |
Easier said than done Mike. I have no idea how to do any of that sadly. Not one of my strong points |
Gremlin500 Member Since: 11 Mar 2022 Location: Newcastle, UK Posts: 1669 ![]() ![]() ![]() |
C4 has a higher ash content and will block the DPF faster.
