Home > Maintenance & Mods (L322) > P0814-01 (28) transmission range display issue
Smitch
United Kingdom 2012 Range Rover Westminster TDV8 Stornoway Grey
Had the P0814-01 DTC pop up in my Westie 4.4 tdv8 when reviewing dtc’s. It was thrown over a hundred miles ago and not seen anything pop up on the console but there seems to be little info on it other than being a “J Gate” issue which I don’t really understand at this point.
No other noticeable issues and wondering if it’s because the shifter was not engaged properly by mistake or if a service is required?
Post #619960 14th Jan 2022 1:27pm
JayGee
One thing you get used to after a while with the GAP IID is a lot of spurious codes and faults. Glitches, low battery voltages, false errors etc.
Don't worry unless it's persistent fault that reappears after clearing the codes. 2012 TDV8 Vogue (L322)
Post #619962 14th Jan 2022 2:06pm
boy1der_uk
England 2012 Range Rover Westminster TDV8 Stornoway Grey
I’ve just had this over the past few days, found the rotary dail would stick in D or R and couldn’t get it to move, switch the engine off and it automatically went to P started up again and it was fine, scanned when I got home and found the same code P0814-01, reset it and turned the car on and off and it’s gone but im not convinced it’s a nothing fault, and have a sneaky suspicion it’ll return. Has anyone any experience with this and the causes and remedy to it. Any help would be appreciated.
 Best Regards Lee
Post #706588 11th Dec 2024 9:30am
RRPhil
The manual seems to indicate that it’s caused by an LED failure and to ‘suspect the transmission shift module’
Phil
Post #706624 11th Dec 2024 3:32pm
boy1der_uk
Thanks Phil, apparently there’s a place on eBay called ElecFIX that repair alsorts of electronic modules do I think I’ll be in touch with them in the future should the fault return. If it does I’ll feedback on here. 👍 Best Regards Lee
Post #706651 11th Dec 2024 11:17pm
