![]() | Home > Maintenance & Mods (L322) > P0814-01 (28) transmission range display issue |
One thing you get used to after a while with the GAP IID is a lot of spurious codes and faults. Glitches, low battery voltages, false errors etc.
boy1der_uk Member Since: 09 Jan 2024 Location: Bradford West Yorkshire Posts: 15 ![]() ![]() ![]() |
I’ve just had this over the past few days, found the rotary dail would stick in D or R and couldn’t get it to move, switch the engine off and it automatically went to P started up again and it was fine, scanned when I got home and found the same code P0814-01, reset it and turned the car on and off and it’s gone but im not convinced it’s a nothing fault, and have a sneaky suspicion it’ll return. Has anyone any experience with this and the causes and remedy to it. Any help would be appreciated.
RRPhil Member Since: 22 Aug 2011 Location: Blackburn, Lancashire Posts: 982 ![]() ![]() |
The manual seems to indicate that it’s caused by an LED failure and to ‘suspect the transmission shift module’
Thanks Phil, apparently there’s a place on eBay called ElecFIX that repair alsorts of electronic modules do I think I’ll be in touch with them in the future should the fault return. If it does I’ll feedback on here. 👍 Best Regards Lee |
