![]() | Home > Maintenance & Mods (L322) > Tailgate glass side trim |
cass Member Since: 12 Oct 2011 Location: northumberland Posts: 755 ![]() ![]() |
I binned mine when they started corroding and haven’t noticed any difference with water dripping. |
DrRob Member Since: 16 Apr 2015 Location: Petersfield, Hampshire Posts: 4332 ![]() ![]() ![]() |
Ditto. Noticed no difference after I binned them. Gone to a good home: 2011 4.4 TDV8 Vogue SE Buckingham Blue with Ivory and clear glass = "Rory"
Baltic Blue Member Since: 13 Aug 2015 Location: North Wales Posts: 3811 ![]() ![]() ![]() |
I doubt you will have much luck getting them to stick to the glass once you have treated them with waxoyl.
kevinp Member Since: 28 Sep 2019 Location: Telford Posts: 1291 ![]() ![]() ![]() |
Thanks guys. Going to go out with a jug of water then and see what's happening.
mjdronfield Member Since: 04 Nov 2011 Location: Derbyshire Posts: 7895 ![]() ![]() ![]() |
They stop some water… it’s better than having them not fitted, compared to the TD6 I had. I don’t have to quickly reach under and whip the parcel shelf out the way as I open the tailgate. Especially having an Ivory interior….
Yes, they aren't cheap. £70 the pair. Thanks. |
Mr Tee Member Since: 13 Dec 2010 Location: Near Wackyjim Posts: 2681 ![]() ![]() ![]() |
IIRC i replaced mine on my old 322. what a proper pain in the tits of a job that was.. |
Mr Tee, can you remember if they stopped the parcel shelf getting wet?
RR2B Member Since: 04 Aug 2020 Location: Rowlands Castle Posts: 255 ![]() ![]() ![]() |
I've learnt to open the tailgate sloooowly when wet to allow the water to drain down the side channels without splashing the parcel shelf. 2011MY 4.4TDV8 Autobiography Baltic Blue
So it is a common issue then. Thanks for the info. |
Range Rover L322 Member Since: 03 Sep 2019 Location: South West Posts: 334 ![]() ![]() |
I replaced them with LR parts. Expensive but I wanted to keep it orginal. If you fit them properly (and clean the glass really well) they stay on nicely. Bit fiddly to get the rubber in.
4434Morrison Member Since: 02 Mar 2020 Location: Folkestone Posts: 185 ![]() ![]() ![]() |
I replaced mine with original parts from Duckworths. Found that they came loose when the car was being washed. Added silicon adhesive inside the channel then re-fitted and ne'er a problem since. I prefer them fitted as they do channel the water away from the interior as they are designed to do. 2012 4.4 TDV8 Vogue SE Current
That's exactly what I wanted to hear mate. I've got some silicone so will apply some as well. Thanks very much. |
Klunk Member Since: 12 Jul 2021 Location: North wales Posts: 72 ![]() |
How hard are these to get out ?
