Home > Maintenance & Mods (L322) > Tailgate glass side trim
kevinp
Can anybody tell me if the rear tailgate glass side rubber trims [ded500180/190] stop water dripping onto the rear parcel shelf when you open the tailgate when it's raining?
I know some cars seem to not have had them fitted from new but just wondered if any owners that do have them fitted could comment please.
I know they rot but I would put some waxoil on them before fitting.
Thanks Kev.
Post #619767 13th Jan 2022 1:07am
cass
I binned mine when they started corroding and haven’t noticed any difference with water dripping.
Post #619769 13th Jan 2022 4:13am
DrRob
Ditto. Noticed no difference after I binned them. Gone to a good home: 2011 4.4 TDV8 Vogue SE Buckingham Blue with Ivory and clear glass = "Rory"
Post #619774 13th Jan 2022 7:55am
Baltic Blue
I doubt you will have much luck getting them to stick to the glass once you have treated them with waxoyl.
One of mine corroded soI removed it, but the other side is bonded to the glass and won’t budge.
Post #619778 13th Jan 2022 8:45am
kevinp
Thanks guys. Going to go out with a jug of water then and see what's happening.
Mike, I thought they pushed into the the gap between the glass and tailgate, didn't realise they bonded the whole length, I thought just the ends. Thumbs Up
Post #619779 13th Jan 2022 9:15am
mjdronfield
They stop some water… it’s better than having them not fitted, compared to the TD6 I had. I don’t have to quickly reach under and whip the parcel shelf out the way as I open the tailgate. Especially having an Ivory interior….
That said, like most, mine are corroding and looking a bit unsightly… don’t think replacements are particularly cheap either.
Previous cars :
2003 Range Rover Vogue TD6
1999 Discovery Td5 ES
1995 BMW M5 3.8 6 speed
1992 BMW M5 3.8
1988 BMW 735i SE
1989 Ford Sierra XR4x4 2.9i
1981 Ford Fiesta Supersport
Post #619782 13th Jan 2022 9:23am
kevinp
Yes, they aren't cheap. £70 the pair. Thanks.
Post #619785 13th Jan 2022 9:30am
Mr Tee
IIRC i replaced mine on my old 322. what a proper pain in the tits of a job that was.. Big Cry
Post #619805 13th Jan 2022 11:55am
kevinp
Mr Tee, can you remember if they stopped the parcel shelf getting wet?
I don't think mine has ever had any fitted.
Post #619817 13th Jan 2022 1:41pm
RR2B
United Kingdom 2011 Range Rover Autobiography 4.4 V8 Baltic Blue
I've learnt to open the tailgate sloooowly when wet to allow the water to drain down the side channels without splashing the parcel shelf. 2011MY 4.4TDV8 Autobiography Baltic Blue
TVR Griffith
Alfa Romeo Mito QV
Post #619870 13th Jan 2022 6:52pm
kevinp
So it is a common issue then. Thanks for the info.
Post #619881 13th Jan 2022 7:52pm
Range Rover L322
I replaced them with LR parts. Expensive but I wanted to keep it orginal. If you fit them properly (and clean the glass really well) they stay on nicely. Bit fiddly to get the rubber in.
I like them but others (like DR Rob) feel it's a neater, cleaner line without. He has great taste and experience too so it's 50/50!..
Post #619921 14th Jan 2022 12:16am
4434Morrison
United Kingdom 2012 Range Rover Vogue SE TDV8 Santorini Black
I replaced mine with original parts from Duckworths. Found that they came loose when the car was being washed. Added silicon adhesive inside the channel then re-fitted and ne'er a problem since. I prefer them fitted as they do channel the water away from the interior as they are designed to do. 2012 4.4 TDV8 Vogue SE Current
2015 E220 with AMG Sport Pack - Currently driven by my son
2010 3.6 TDV8 Vogue - Written off by my son
Post #619927 14th Jan 2022 6:39am
kevinp
That's exactly what I wanted to hear mate. I've got some silicone so will apply some as well. Thanks very much.
Post #619934 14th Jan 2022 9:43am
Klunk
How hard are these to get out ?
mine are both a bit corroded although not exactly falling off
Don’t want to crack the glass!
Post #630734 5th May 2022 7:18pm
