Home > General (L405) > How to Prevent ...being stolen? |
kungfupanda Member Since: 24 Jun 2013 Location: Manchester Posts: 221 |
That’s all you can do really l. If it were your own car I would have suggested an immobiliser such as a Ghost or Pandora. |
8th Jan 2022 7:16pm |
socialrover Member Since: 03 Dec 2010 Location: Yorkshire Posts: 138 |
Hello ,
8th Jan 2022 11:05pm |
garyRR Member Since: 13 Mar 2021 Location: Hampshire Posts: 1477 |
Sorry to hear. I know they're top targets because of their value and desirability.
8th Jan 2022 11:13pm |
Cam-Tech-Craig Member Since: 03 Aug 2011 Location: Gloucestershire Posts: 16294 |
The above and of course if they cant speak to your KVM through the OBD2 then they cannot write to a new key either!
9th Jan 2022 12:13am |
Another option if leaving the vehicle for an amount of time or going on holiday is that you could simply remove the engine relay, starter relay or ECU fuse - a 10 second job. 2015 Range Rover Autobiography 4.4 SDV8 |
9th Jan 2022 12:20am |
Indeed... |
9th Jan 2022 12:23am |
How do you turn off access through the OBD2 but still be able to use it yourself for diagnostics etc? 2015 Range Rover Autobiography 4.4 SDV8 |
9th Jan 2022 12:28am |
Ive sent you the information via a PM sir... |
9th Jan 2022 12:48am |
Thanks for the tips Craig ,
9th Jan 2022 8:47am |
Update - for interest
9th Jan 2022 9:00am |
I genuinely think there should be an Immediate 'aggrovation' payment for non-fault claims.
9th Jan 2022 10:51am |
Kot Member Since: 10 Mar 2021 Location: broadland Posts: 1225 |
The best tracker is the option which has added protection of VHF. This can allow tracking under ground and in containers plus the installer does not hide it in the standard known position in the car.
9th Jan 2022 10:52am |
Hi Kot ,
9th Jan 2022 12:12pm |
Phil. Member Since: 19 Apr 2010 Location: West Midlands Posts: 786 |
I have posted this before on here so am ok with it being public.
9th Jan 2022 1:26pm |
