![]() | Home > General (L405) > How to Prevent ...being stolen? |
kungfupanda Member Since: 24 Jun 2013 Location: Manchester Posts: 223 ![]() ![]() ![]() |
That’s all you can do really l. If it were your own car I would have suggested an immobiliser such as a Ghost or Pandora. |
socialrover Member Since: 03 Dec 2010 Location: Yorkshire Posts: 140 ![]() ![]() |
Hello ,
garyRR Member Since: 13 Mar 2021 Location: Hampshire Posts: 1480 ![]() ![]() |
Sorry to hear. I know they're top targets because of their value and desirability.
The above and of course if they cant speak to your KVM through the OBD2 then they cannot write to a new key either!
Another option if leaving the vehicle for an amount of time or going on holiday is that you could simply remove the engine relay, starter relay or ECU fuse - a 10 second job. 2015 Range Rover Autobiography 4.4 SDV8 |
Indeed... |
How do you turn off access through the OBD2 but still be able to use it yourself for diagnostics etc? 2015 Range Rover Autobiography 4.4 SDV8 |
Ive sent you the information via a PM sir... |
Thanks for the tips Craig ,
Update - for interest
I genuinely think there should be an Immediate 'aggrovation' payment for non-fault claims.
Kot Member Since: 10 Mar 2021 Location: broadland Posts: 1261 ![]() ![]() |
The best tracker is the option which has added protection of VHF. This can allow tracking under ground and in containers plus the installer does not hide it in the standard known position in the car.
Hi Kot ,
Phil. Member Since: 19 Apr 2010 Location: West Midlands Posts: 788 ![]() ![]() ![]() |
I have posted this before on here so am ok with it being public.
