Home > Technical (L322) > Strange starting issue and limp mode under heavy acceleratio
Ian Thompson
United Kingdom 2011 Range Rover Vogue 4.4 V8 Santorini Black
2011 4.4 TDV8 Vogue 86k miles
When pressing engine start button the engine turns over for a long time but does not fire then times out. Pressing button again the engines turns over for some time then eventually fires and sounds a little rough for a minute, a bit like a misfire that fades away. All is ok after that unless I use heavy acceleration when the engine management kicks in and I get the Reduced Performance message and the vehicle eventually can only maintain approx 10mph in any gear.
I'm thinking this sounds very like a fuel pump issue but which one if at all?
Ideas on an Xmas card please, or a postcard !!
Post #617193 21st Dec 2021 10:12pm
cass
Simple things first, has it ever had a fuel filter changed?
Any codes?
Post #617201 21st Dec 2021 11:15pm
DrRob
Any fault codes rearing up on a scan? Gone to a good home: 2011 4.4 TDV8 Vogue SE Buckingham Blue with Ivory and clear glass = "Rory"
Post #617212 22nd Dec 2021 7:49am
Ian Thompson
I have only owned this for 3 months and have no info on if fuel filters have ever been changed.
I do not have any scanning capability to access any error codes (mmm, I spy a self Xmas present coming!)
Post #617221 22nd Dec 2021 9:03am
DrRob
I'd be taking it to a decent LR independent specialist for diagnosis. Avoid main dealers. Gone to a good home: 2011 4.4 TDV8 Vogue SE Buckingham Blue with Ivory and clear glass = "Rory"
Post #617224 22nd Dec 2021 9:31am
Ian Thompson
Any tips for a good specialist anywhere near Dover, Kent? 2011 4.4 TDV8 Vogue Santorini Black with black interior and glass
2004 TD5 Discovery 2 - gone
2002 Freelander 1.8 - gone
Post #617229 22nd Dec 2021 10:17am
DrRob
I keep a record on Google Maps when I hear good reviews.
Here you go:
East Kent Automotive Ltd.
Landmark Land Rover
Discovery Garage
AHL Engineering.
Only in order of distance from Dover. No prior personal experience of any of them. Gone to a good home: 2011 4.4 TDV8 Vogue SE Buckingham Blue with Ivory and clear glass = "Rory"
Post #617230 22nd Dec 2021 10:24am
Ian Thompson
So to revisit this I have now worked out this only happens when I get very low on fuel then lasts for a few days after I fill up, slowly returning to normal. Anyone got any clues on what this indicates? 2011 4.4 TDV8 Vogue Santorini Black with black interior and glass
Post #626599 21st Mar 2022 10:02am
JayGee
You need to get this checked by a specialist or get a GAP IID and read the codes. Anything else is a shot in the dark 2012 TDV8 Vogue (L322)
Post #626600 21st Mar 2022 10:07am
DrRob
As above, get the codes read by an independent specialist - I gave you a list Whistle Thumbs Up Gone to a good home: 2011 4.4 TDV8 Vogue SE Buckingham Blue with Ivory and clear glass = "Rory"
Post #626603 21st Mar 2022 10:49am
