![]() | Home > Technical (L322) > Strange starting issue and limp mode under heavy acceleratio |
cass Member Since: 12 Oct 2011 Location: northumberland Posts: 751 ![]() ![]() |
Simple things first, has it ever had a fuel filter changed?
DrRob Member Since: 16 Apr 2015 Location: Petersfield, Hampshire Posts: 4318 ![]() ![]() ![]() |
Any fault codes rearing up on a scan? Gone to a good home: 2011 4.4 TDV8 Vogue SE Buckingham Blue with Ivory and clear glass = "Rory"
Ian Thompson Member Since: 29 Sep 2021 Location: Dover, Kent Posts: 10 ![]() ![]() ![]() |
I have only owned this for 3 months and have no info on if fuel filters have ever been changed.
I'd be taking it to a decent LR independent specialist for diagnosis. Avoid main dealers. Gone to a good home: 2011 4.4 TDV8 Vogue SE Buckingham Blue with Ivory and clear glass = "Rory"
Any tips for a good specialist anywhere near Dover, Kent? 2011 4.4 TDV8 Vogue Santorini Black with black interior and glass
I keep a record on Google Maps when I hear good reviews.
So to revisit this I have now worked out this only happens when I get very low on fuel then lasts for a few days after I fill up, slowly returning to normal. Anyone got any clues on what this indicates? 2011 4.4 TDV8 Vogue Santorini Black with black interior and glass
You need to get this checked by a specialist or get a GAP IID and read the codes. Anything else is a shot in the dark 2012 TDV8 Vogue (L322) |
As above, get the codes read by an independent specialist - I gave you a list |
