![]() | Home > Maintenance & Mods (L322) > Suspension fault |
rjff Member Since: 28 Oct 2017 Location: Cambridgeshire Posts: 1196 ![]() ![]() ![]() |
There are quite a few threads on this around on here and if you look in the WM in the Wiki under suspension fault codes you'll see the code identfied and suggested possible causes.
bishbosh10 Member Since: 25 Apr 2013 Location: North Somerset Posts: 344 ![]() ![]() |
Very easy to drill through the exhaust silencer. Do it off the vehicle and make sure all the swarf is blown out before refitting. Bish.
knares Member Since: 22 Jun 2017 Location: Perth WA Posts: 768 ![]() ![]() ![]() |
noted RR 2005 4.4 petrol
ok i found the breather, looks like new, so dose the commpressor, i havent removed it, dont know if i should RR 2005 4.4 petrol
Hi Knares
@ Knares, if i remember correctly that is the PRV - pressure relief valve.
rjff no you didn’t miss any thing, after reading C11ONX post it got me thinking about mine
