Home > Technical (L322) > 2010-2012 transfer box fill capacity
Graham4242
United Arab Emirates 2011 Range Rover Autobiography 5.0 SC V8 Alaska White
I’m working my way through the driveline fluids, gearbox has been done, next the front and rear diffs. The 2010 onwards service manual says the fill plug is not to be used as a level indicator. I’ve found the fill capacities for the diffs but can’t find anything about filling the transfer box. Does anyone know what is the fill volume for the transfer box is or if the transfer box fill plug can be used as a level indicator. Current
2011 Autobiography, 2014 Vogue SE Supercharged
Previous
2016 Cayman GTS
2015 Cayenne Turbo
2016 911 Turbo
2013 Audi S8
2014 Cayman S
2003 Alpina B5s
1998 M5
1993 M5
Post #616546 15th Dec 2021 10:15pm
this is from the WM but its best if you confirm yourself by reading it...
Post #616547 15th Dec 2021 10:24pm
Graham4242
Thanks for that, I need to brush up on my control F search skills.
Diffs done now I just need to find the transfer box oil which in sunny Qatar is tricky to say the least. Current
Previous
2016 Cayman GTS
2015 Cayenne Turbo
2016 911 Turbo
2013 Audi S8
2014 Cayman S
2003 Alpina B5s
1998 M5
1993 M5
Post #616792 18th Dec 2021 7:55am
