Home > Technical (L322) > Humming noise when going uphill
lodelanelad
United Kingdom 2006 Range Rover Supercharged 4.2 SC V8 Santorini Black
Hello - long term lurker here... This place really is an amazing resource! I have had my 05 4.2 Supercharged for a while now and it has been trouble free so far...apart from on the last few trips I have noticed a strange humming noise coming from the drivers side wheel (UK - i.e. the front rigjt side of the car) which can only be felt when going sub 20mph (it seems very closely linked to road speed) when the car is going uphill...any ideas? Initially I thought the torque converter - but the revs aren't fluctuating - the gear shifts are smooth and the sound is very concentrated to the front right hand side of the car...
Post #616377 14th Dec 2021 7:44pm
maric995
Croatia 2006 Range Rover HSE 4.4 V8 Zambezi Silver
Mine 4.4 ajv8 does this as well. I heard that sound 2 years ago, but I never worried too much as it doesn't seem to get any louder by the time that went. I believe it is torque converter related (mine currently on 260 000km) RR HSE 4.4 2006 LPG
Post #616423 15th Dec 2021 9:10am
lodelanelad
Is yours only on one side of the vehicle? Mine only has 75k on the clock and doesn't seem to have any other TC symptoms...but it could still be I suppose
Post #616437 15th Dec 2021 10:14am
MartinD
Scotland 2011 Range Rover Vogue SE TDV8 Santorini Black
Brake shield, perhaps? 2011 4.4 TDV8 Vogue SE - 'Black Betty'
2000 4.0 P38 HSE - 'Green Goblin' - Gone.
Audi..Mini..BMW..
Post #616438 15th Dec 2021 10:16am
lodelanelad
The brakes were changed by the previous owner - how do I check this?
Post #616450 15th Dec 2021 10:48am
Wanderer83
United Kingdom 2006 Range Rover Supercharged 4.2 SC V8 Rimini Red
Diff needing oil change?
Post #616738 17th Dec 2021 4:39pm
lodelanelad
Just to square this one off - it was a corroded gear shifter linkage of all things....Sprayed down with wd40 and then moved all of the way forwards and back - with the whole process repeated a few times. I hope this helps someone else in the future as it was driving me mad!
Post #632559 22nd May 2022 5:57pm
