![]() | Home > Technical (L322) > Humming noise when going uphill |
maric995 Member Since: 04 Apr 2019 Location: zagreb Posts: 58 ![]() ![]() ![]() |
Mine 4.4 ajv8 does this as well. I heard that sound 2 years ago, but I never worried too much as it doesn't seem to get any louder by the time that went. I believe it is torque converter related (mine currently on 260 000km) RR HSE 4.4 2006 LPG |
lodelanelad Member Since: 14 Dec 2021 Location: London Posts: 57 ![]() ![]() ![]() |
Is yours only on one side of the vehicle? Mine only has 75k on the clock and doesn't seem to have any other TC symptoms...but it could still be I suppose |
MartinD Member Since: 20 Oct 2010 Location: Edinburgh Posts: 303 ![]() ![]() ![]() |
Brake shield, perhaps? 2011 4.4 TDV8 Vogue SE - 'Black Betty'
The brakes were changed by the previous owner - how do I check this? |
Wanderer83 Member Since: 01 Aug 2021 Location: London Posts: 27 ![]() ![]() ![]() |
Diff needing oil change? |
Just to square this one off - it was a corroded gear shifter linkage of all things....Sprayed down with wd40 and then moved all of the way forwards and back - with the whole process repeated a few times. I hope this helps someone else in the future as it was driving me mad! |
