![]() | Home > Maintenance & Mods (L405) > Rear lens replacement L405 |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35487 ![]() ![]() |
you'll have to soften the bonding between the lens and light unit to remove it..
Pendle Member Since: 12 Dec 2021 Location: Hampshire Posts: 23 ![]() ![]() ![]() |
Thanks
a strong clear silicon glue will do the job..there are many brands available.. ... - .- -.
Matt Buckland Member Since: 27 Nov 2018 Location: Derbyshire Posts: 65 ![]() ![]() ![]() |
There’s a video on the PowerfulUK site in which they “de-tango” some D3 headlights, swapping out the orange reflector for a clear one, by placing the headlights in an oven to soften the adhesive and separating the lens from light body.
Thanks Matt
Hi Matt
Thanks Matt
AND !!
Oh, sorry, I should have posted the link…but you found it in the end |
JCW Member Since: 13 Apr 2013 Location: Cotswolds Posts: 890 ![]() ![]() ![]() |
I’m not sure the rear light lenses are as straightforward to replace as I think they’re plastic welded opposed using mastic which can be softened with heat per the headlights.
Cam-Tech-Craig Member Since: 03 Aug 2011 Location: Gloucestershire Posts: 16312 ![]() ![]() ![]() |
Yes, they are sonic welded together... I would simply break the old cover off bit by bit Careful NOT to touch any chrome inside as it'll be ruined by the oil in your skin... Then glue the replacement on using some form of PU |
Thanks Cam'
have you considered looking on ebay for a replacement light unit...you might lucky and find cheap one.. ... - .- -.
Muiryden Member Since: 28 Feb 2017 Location: Highlands Posts: 3 ![]() ![]() ![]() |
No disrespect to PowerfulUK, great company I have used many times and I just love the videos!! However I replaced the lense on my L405 a few weeks back. Spent at least 3 hours on it and wasnt happy with the end result as you are effectivly guessing where to re-bond the new lense. I would go 2nd hand route. |
