Home > Maintenance & Mods (L405) > Rear lens replacement L405
Page 1 of 3 123>
Pendle
United Kingdom 2016 Range Rover SVAutobiography SDV8 Firenze Red
Hi, I have bought a rear lens from powerfuluk.com
Has anyone replaced a lens?
Mine is cracked but lamp unit is undamaged
Any tips would be appreciated
Thanks
Pendle
Post #616100 13th Dec 2021 12:33pm
you'll have to soften the bonding between the lens and light unit to remove it..
putting in the oven can do this or a heat gun...its a tricky job and does take time and fettling..
once the old lens is off its a matter of re-bonding the new lens.. ... - .- -.
Post #616117 13th Dec 2021 1:28pm
Pendle
Thanks
What did you use to bond the new lens?
Pendle
Post #616121 13th Dec 2021 1:34pm
a strong clear silicon glue will do the job..there are many brands available.. ... - .- -.
Post #616124 13th Dec 2021 1:35pm
Matt Buckland
United Kingdom 2017 Range Rover Autobiography TDV6 Santorini Black
There’s a video on the PowerfulUK site in which they “de-tango” some D3 headlights, swapping out the orange reflector for a clear one, by placing the headlights in an oven to soften the adhesive and separating the lens from light body.
I did that a few years ago on a D3, following closely their video advice and it worked well. I imagine the process for your 405 is similar, so it would be worth watching their D3 video.
Good luck! L460 460e PHEV AB. Belgravia green.
Previous toys:
L405 2017 TDV6 AB
4.4 TDV8 Westminster. Santorini Black
1976 Lightweight
4.0l P38
2 Disco 3s
Jaguar XJ6 (X350)
Jaguar XJ8 (X308)
Jaguar XK
Jaguar XK8. Confirmed JLR nut.
Post #616137 13th Dec 2021 2:18pm
Pendle
Thanks Matt
I will take a look
Pendle
Post #616151 13th Dec 2021 3:55pm
Pendle
Hi Matt
Sorry, I cannot find the video.
Do you have a link?
Pendle
Post #616155 13th Dec 2021 4:44pm
Pendle
Thanks Matt
Maybe I have just found it !
Thanks Pendle
Post #616156 13th Dec 2021 4:47pm
Pendle
AND !!
Post #616157 13th Dec 2021 4:51pm
Matt Buckland
Oh, sorry, I should have posted the link…but you found it in the end Smile
I had my D3 light in and out of the oven several times at first to get the adhesive to soften. On the second headlight, I had the courage to leave it in slightly longer and it was really straight forward.
I hope you get it sorted easily enough. L460 460e PHEV AB. Belgravia green.
Previous toys:
L405 2017 TDV6 AB
1976 Lightweight
4.0l P38
2 Disco 3s
Jaguar XJ6 (X350)
Jaguar XJ8 (X308)
Jaguar XK
Post #616162 13th Dec 2021 5:29pm
JCW
United Kingdom 2010 Range Rover Autobiography TDV8 Santorini Black
I’m not sure the rear light lenses are as straightforward to replace as I think they’re plastic welded opposed using mastic which can be softened with heat per the headlights.
Happy to be corrected though Thumbs Up
Post #616170 13th Dec 2021 6:16pm
Yes, they are sonic welded together... I would simply break the old cover off bit by bit Careful NOT to touch any chrome inside as it'll be ruined by the oil in your skin... Then glue the replacement on using some form of PU Thumbs Up
Post #616258 14th Dec 2021 1:34am
Pendle
Thanks Cam'
I am getting more nervous by the post!
But thanks to all for tips and advice
This is the lens type I plan to replace! L405 SV Autobiography 2016
XJS V12 Convertible 1990
Previous:
L322 Vogue SE 2011
Mazda MX5 1999
Saab 9-5 2.0 SE 2000
Discovery 3 door 300 Tdi 1995
Fiat X1/9 1983
Citroen BX 1.9 GTI Turbo 1987
Austin Princess Vanden Plas 1972
Several too embarrassing to publish and a bunch of Company cars incl RAV4 Honda Accord Coupe and a Bora.
Post #616294 14th Dec 2021 10:42am
have you considered looking on ebay for a replacement light unit...you might lucky and find cheap one.. ... - .- -.
Post #616303 14th Dec 2021 11:25am
Muiryden
United Kingdom 2013 Range Rover Autobiography SDV8 Aintree Green
No disrespect to PowerfulUK, great company I have used many times and I just love the videos!! However I replaced the lense on my L405 a few weeks back. Spent at least 3 hours on it and wasnt happy with the end result as you are effectivly guessing where to re-bond the new lense. I would go 2nd hand route.
Post #621655 28th Jan 2022 12:09pm
Page 1 of 3 123>
